  • 2.3L (N/A & Turbo) Tech
O2 sensor/bung
  • Thread starter Thread starter radartec
  • Start date Start date Mar 21, 2004
radartec
248
Northern CA
Mar 21, 2004
  • Mar 21, 2004
My carb turbo Pace Car does not have an O2 sensor (cause it's so old). I was thinking it would be very important once I start cranking up my boost past 10lbs to know what my air/fuel ratio was. So I have to buy an O2 sensor and bung. Are they all the same? I was seeing some Bosch sensors and bungs advertised. Once I get the sensor/bung where would I get it welded? At the pipe right before the cat? I have a crossunder pipe on my car. Would it be better before or after the turbo? Does it matter? What is a wideband sensor? Is it different?
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Mar 21, 2004
  • Mar 21, 2004
Now, hold on here. An O2 sensor doesn't tell you what your air/fuel ratio is. Moreover I'm not sure how you could add an O2 sensor to a vehicle that never came with one from the factory. Do you mean you want an air/fuel gauge?
radartec
248
Northern CA
Mar 21, 2004
  • Mar 21, 2004
I suppose I should have said that I want to have an air/fuel guage in the car that shows me what the air/fuel mixture is. The other end of the guage is the O2 sensor, no???
Y
youknowit62300
24
Wichita Kansas
Mar 21, 2004
  • Mar 21, 2004
no. you can use an o2 sensor but most people that i know use a/f sensors i believe you can get them at any autopart store but people i know that race at the track use them so they can tune the carb easier
radartec
248
Northern CA
Mar 21, 2004
  • Mar 21, 2004
Hmmm. Maybe I'm not being clear enough. I need to know if I can use a Autometer Cobalt Air/Fuel gauge in conjunction with an O2 sensor or an air/fuel sensor. Is there any other equipment needed? Is it simply hooking the guage up to the sensor that I would mount in the exhaust stream somewhere?
Y
youknowit62300
24
Wichita Kansas
Mar 22, 2004
  • Mar 22, 2004
i am pretty sure that an o2 sensor won't work. and as far as i know the only think you have to do is put the sensor in the exhaust and hook it up to the gauge.
Xanax
103
  • Mar 24, 2004
I don't think an O2 sensor will work either.
A
Anthony M
70
Toledo, OH
Mar 24, 2004
  • Mar 24, 2004
Think about it, an A/F gauge has three wires. One gets a 12V source, one gets the SIG from the O2 sensor, and the other is a ground for the LEDs. Now with the SIG wire for the A/F attached to the O2, what is gonna power the sensor itself?
Im not sure if the EGO circuit is 12 or 5V but maybe you could wire a constant source to supply the O2 sensor...?
Correct me if Im wrong
Anthony
EDIT: If you truely wanna know your air/ fuel ratio, go for a LM1 wideband from Innovative Motorsports. It'll be easier and more accurate
Bearded Forever
Type O Danzigative the Dark
4,927
Vinland
Mar 24, 2004
  • Mar 24, 2004
I agree.
Xanax
103
#10
  • Mar 24, 2004
  • #10
I AGREE
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
A
2020 Ford Mustang GT P0036, P0138, P0141 02 sensor help
  • AmkoA
  • Jul 29, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 5, 2025
skkrtis
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
