o2 sensor problem?
  • Thread starter Thread starter Sanford
  • Start date Start date Jun 9, 2004
Sanford
15
Maryland
Jun 9, 2004
  • Jun 9, 2004
Hey i was just wondering if anyone has had troube with O2 sensors going bad... my car was running horrible all rich and smokin so i checked my timing and changed the o2 sensors and it ran great for about 2 days... then it starting runing bad again... just wonding if anyone had any ideas..thanks brian
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 9, 2004
  • Jun 9, 2004
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
4dStang
Banned
Oct 23, 2002
718
Near St Louis, Missouri
Jun 9, 2004
  • Jun 9, 2004
Did you pull any plug to look for fouling? If you just replaced the 02 sensors, they can't be messed up like you explain after 2 days. I think you have something else causing a rich fault. Check the vacuum line on the top of the fuel pressure regulator, see if it has fuel. If it does, the FPR may need to be replaced. I would try looking at that first and see if that can fix it. That's my guess.
Chris
HISSIN50
34
129
Jun 10, 2004
  • Jun 10, 2004
dont forget the ECT and ACT sensors....they can be out of calibration.....motor thinks it is cold at all times (rich), etc.
it wont necessarily toss a code, as it can be within spec, but incorrect for the situation.
good luck.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
