- Apr 4, 2005
- 5
- 0
- 0
Im not sure if this is the correct place to post this problem, but I'm new so I'll appologize in advance. The problem I am having is on a 1997 Mustang GT, its completely stock except for some flowmasters. The car has been sitting for a while and after I got it out of storage I went to get it inspected..results...P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1). I called the local Ford house and they advised me my car only had two O2 sensors so I replaced the first two I found..which were the ones after the cats. Two days later I took it back to get inspected and the same code showed up. The guy doing the inspection was pretty much worthless, I tried getting some information out of him but all I ended up with was some brochure in spanish..alot of help that was. After searching around on the net for a while I finally figured out I had two more O2 sensors before the cats up by the manifolds and that bank 1 sensor 1 was the pre cat driver side O2 sensor. I replaced it but im still getting an error code. I've had the codes cleared several times but it keeps returning ...any suggestions? Thanks.
