O2 sensor question
Bullitt
Packin' Heat
2,743
Houston, TX
I'm converting my '67 Mustang to EFI, but I've run into a problem with the O2 sensor harness.
I've got a '90 harness for the engine (mass air, A9P computer, etc), but somehow I ended up with an '86 harness for the O2 sensors. They click together, however the '90 sensors are 4 wire and the '86 sensors are 3 wire.
Question is - can I run the 3 wire O2s with a mass-air computer, or do I need to find a correct '90 harness and run the 4 wire sensors?
Thanks!!
It might be that 86's used EGO's, hence one less wire. If so, I'd think that the appropriate HEGO would work alright - it'll just take longer to light off. I think you could also add the necessary wire (since there was a provision for it in OEM form) to achieve whatever you're missing.
Good luck.
