  • SN95 4.6L Mustang Tech
o2 sensor
  • Thread starter Thread starter KILLER EX
  • Start date Start date Jun 5, 2006
KILLER EX
50
Gloucester,Mass
Jun 5, 2006
  • Jun 5, 2006
my mechanic broke one of my front o2 sensors taking it out and i used mil eliminators on the back 2 so he put the rear one in the front is this ok? they are factory sensors he said he had to trim the plug alittle to fit.
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Jun 5, 2006
  • Jun 5, 2006
Front o2 sensors differ from rear o2 sensors.
Im sure you noticed you got a CEL, and your car running rich and like poo. It's because the front sensors help determine your a/f ratio.
Make him buy you new OEM FORD sensors, not bosch or whatever from Autozone.
jstreet0204
939
Winston Salem, NC
Jun 5, 2006
  • Jun 5, 2006
The only difference in the front and rear o2's is the harness. The actual o2 is the same. I have used my rear ones in the front with no issues.
MT1083
1,033
Charlotte, NC
Jun 6, 2006
  • Jun 6, 2006
The front and rear are different. Never swap them. The rears are just moniters not o2
sensors.
RandyStinchcomb
1,159
Randallstown, Md
Jun 6, 2006
  • Jun 6, 2006
very bad idea they are NOT the same. we have seen several cars come in our shop wth the EEC shorted-out because someone did this. not a good idea, unless you like to spend alot of $$$ wth me
oh......and please DO NOT buy aftermarket ones
jstreet0204
939
Winston Salem, NC
Jun 6, 2006
  • Jun 6, 2006
sensors.
They are not different. The EEC uses them for a different purpose. Other than the pigtail, the sensors are exactly the same and can be swapped.
jstreet0204
939
Winston Salem, NC
Jun 6, 2006
  • Jun 6, 2006
I usually agree with you but not on this one. They are the same four wire sensor, and I have datalogged the exact same readings from both sensors. If some one shorted them out it was because of their wiring job when they changed the pigtail.
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
