o2 sensors
  • Thread starter Thread starter dkins419
  • Start date Start date Jul 6, 2005
dkins419
187
Michigan
Jul 6, 2005
  • Jul 6, 2005
what did you guys do/ use to get your o2 sensors out? Is there a special tool to use because i cannot get anything in there ot get it out. thanks
z9_87
332
Urbana, IL
Jul 6, 2005
  • Jul 6, 2005
I can't remember the size but you just use a wrench, maybe 1" or 3/4", it's bigger.
Curse
791
El Paso, TX
Jul 6, 2005
  • Jul 6, 2005
7/8" wrench works for me. If you have never taken them off before, they might be a little hard to break loose. Good luck
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Jul 6, 2005
  • Jul 6, 2005
there is such thing as an o2 sensor wrench.. but 7/8 workd for me 2
illwood
636
Worcester, MA
Jul 6, 2005
  • Jul 6, 2005
I've seen O2 sensor sockets before. They have a notch in them for the electrical pigtail.
Curse
791
El Paso, TX
Jul 6, 2005
  • Jul 6, 2005
But those sockets are for cars that have the O2 sensor in the header or somewhere else you can't get a wrench on them. On our cars a normal 7/8 wrench is all you need.
HISSIN50
34
129
Jul 6, 2005
  • Jul 6, 2005
soaking the bung in PB, etc might help.
Good luck.
z9_87
332
Urbana, IL
Jul 8, 2005
  • Jul 8, 2005
Get a 6 sided 7/8" inch wrench with a small hole on one of the sides that will let you put the wires through. That way you wont round it and it'll hold with however much torque you give it.
HISSIN50
34
129
Jul 8, 2005
  • Jul 8, 2005
Like a line wrench.
LT1Killa
192
#10
  • Jul 8, 2005
  • #10
I JUST got mine out about 10 minutes ago. One was really stubborn. On the first one I used a 15 inch crescent wrench and it came out slowly. The other one , I tried the stupid O2 socket, it just stripped it, so I had to use an 8 inch pipe wrench and a 2 ft breaker bar (with some pb blaster) and it came out.
What does it mean if they are a light gray to white color??
dkins419
187
Michigan
Jul 8, 2005
#11
  • Jul 8, 2005
  • #11
did you guys drop down your exhaust? I have the stock exhaust so its welded on hangars and I cant use use anythign long to get in there. Im just gonna take it to a guy tomorrow that I know of at a shop.
8950HO
658
#12
  • Jul 8, 2005
  • #12
02 sensor socket or a 7/8" 60 degree deep offset wrench for the really stuck ones.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
Fox 5.0 Mustang Tech Jul 22, 2026
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
