o2s
  • Thread starter Thread starter Graydon5oh
  • Start date Start date Nov 13, 2006
Graydon5oh
215
ARKANSAS
Nov 13, 2006
  • Nov 13, 2006
ok got a question about o2 sensors i didnt have them on my 87 and never had problems. well my 86 didnt have them on it when i got it and i have problems with bucking and missing, but not all the time. i have changed injectors,regulater, wires, plugs, cap, rotor, coil. so im getting limited. im gonna try the fuel filter and pump also. so in other words could this be my prob and even if not would it be a good idea to get some o2s back on it
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Nov 14, 2006
  • Nov 14, 2006
yes
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 14, 2006
  • Nov 14, 2006
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Qtrhrse23
