Oasis Report, Please?
  • Thread starter Thread starter benderofbows
  • Start date Start date May 17, 2009
benderofbows
  • May 17, 2009
Hi, new to the forum.
Just bought a GT, with only a couple of months of warranty left, and am curious about the car's repair history.
Can someone run an Oasis report on 1ZVHT82H865167257 ?
THANKS
benderofbows
  • May 19, 2009
bump
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 19, 2009
  • May 19, 2009
OASIS RESULT:
1ZVHT82H865167257
USA
EN
05/19/2009
16:33:43
FCXWS447
© Copyright 2002-2008 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 MUSTANG BODY STYLE
2 DOOR COUPE GT ENGINE
4.6L 3V SOHC
TRANSMISSION
T3650 5-SPEED MANUAL AXLE CODE
CD ENGINE CALIBRATION
6ZF2G80A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
Click here for CUDL
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/15/2006 BUILD DATE
12/03/2005 SALE MILEAGE
00093
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0994 - USA 2006 NEW 60/60,000 P'TRAINCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: MICHAEL GROEN
OPTIONS:
EXPIRATION DATE: 07/15/2011
DISTANCE: 60,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 40919
ESP CONTRACT START DATE: 07/15/2006
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
04/25/2009
DEALER: LaFayette Ford
WARRANTY CLAIM NUMBER: 083955 ODOMETER: 022347M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 96R MOTORCRAFT BATTERY 001 10654C 42 DOES NOT OPERATE PROPERLY
000 10654C1
NEC, TO VERIFY CONCRN. NO CRANK. NEC, TO TEST STARTING CIRCUIT AND BATTERY. TESTED BATTERY. BATTERY FAILED. DTC # 146CGPJTS0980. ACES # X961S. REPLACED BATTERY AND CHECKED CHARGING SYSTEM. ALL FUNCTIONS OK.
05/27/2008
DEALER: Sanford Ford Lincoln Mercury,
WARRANTY CLAIM NUMBER: 004702 ODOMETER: 020416M
LABOR OP
CONDITION CODE
CONDITION DESC
000 08C02B
. . REPROGRAMMED RCM PER RECALL 08C02
Click Here for Full Warranty History
| On-line 1878
END OF OASIS REPORT FOR 1ZVHT82H865167257
Standard Claims List For Model Year 2006
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1ZVHT82H865167257 C/ZF F C/BJ * C/B CL C/SK C/HZ 03-DEC-2005 15-JUL-2006 121777 USA 6 7S13 180103 * 14405 * G07 28 9832
AWS Claim Key: 2593978 Trx Code: 2 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 00960 - * Name: LAFAYETTE FORD Ph: 910-4240281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:02-JAN-2007 Doc #:03046451
Cust Comments: CS THAT DRIVERSIDE WINDOW IS INOP WILL GO UP WITH THE AUTOMATIC BUT WILL NOT GO DOWN
Tech Comments: CK FOR DRIVERS WINDOW WILL NOT GO DOWN NEC TO PREFORMED INITIALIZE FOR POWER WINDOW PER TSB BUT THAT DID NOT FIX THE CONCERN NEC TO TRACE OPEN IN CIRCUIT OPEN WIRE # 314 TN LB FROM THE MASTER SWITCH TO POWER WINDOW MOTOR HARNESS 14405
1ZVHT82H865167257 C/ZF F C/BJ * C/B CL C/SK C/HZ 03-DEC-2005 15-JUL-2006 121777 USA 23 6R08 * * * * * * 20416
AWS Claim Key: 6261092 Trx Code: 08C02 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 01267 - * Name: SANFORD FORD LINCOLN MERCURY, INC. Ph: 919-7752221 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:27-MAY-2008 Doc #:00470201
Cust Comments: RECALL 08C02, PASS AIRBAG
Tech Comments: . . REPROGRAMMED RCM PER RECALL 08C02
1ZVHT82H865167257 C/ZF F C/BJ * C/B CL C/SK C/HZ 03-DEC-2005 15-JUL-2006 121777 USA 34 7A01 140101 BXT 96 R D02 42 22347
AWS Claim Key: 8150313 Trx Code: E83 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 00960 - * Name: LAFAYETTE FORD Ph: 910-4240281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:25-APR-2009 Doc #:08395551
Cust Comments: CK UNIT WILLNOT START DOES NOT CRANK OVER
Tech Comments: NEC, TO VERIFY CONCRN. NO CRANK. NEC, TO TEST STARTING CIRCUIT AND BATTERY. TESTED BATTERY. BATTERY FAILED. DTC # 146CGPJTS0980. ACES # X961S. REPLACED BATTERY AND CHECKED CHARGING SYSTEM. ALL FUNCTIONS OK.
Vehicle Information Report
GENERAL VEHICLE INFORMATION: (Related Claims)
VIN: 1ZVHT82H865167257 Veh Line: C/ZF - MUSTANG (S197) [05-10] Eng Serial No: 110558177709
Model Year: 2006 Market Derived: F - FORD Body Shell: *
Veh Type: C Drive Code: C/B - 2 WHL L/H REAR DRIVE Engine: C/HZ - MOD 4.6L 3V OHC VCT NA ALV8
Inv. Dealer: * Body Cab Style: C/BJ -2 DOOR COUPE-4 LITE Transmission: C/SK - 5 SPD MAN TRANS TR3650
Version/Series: * - [N/A]
Trace Eng Serial No:
---------1----------2---------3--------4---------5-----------6----------7---------8
E1900 22110558177709 6S 837 AA
Trace Trans Serial No:
TG400 11260513910 6R33 7003 AA
BUILD INFORMATION:
Region: NA - ########## Plant: CL - FLATROCK ASSEMBLY PLANT - USA
Country: USA - ########## Prod Date: 03-DEC-2005
SALE INFORMATION:
Region: NA - ########## Selling Dealer: 121777 -*
Country: USA - ########## Selling Dlr St/Prov: NC
Buyer St/Prov: *
Arrival Date: 14-DEC-2005 Red Carpet Lease: *
Sale Date: 15-JUL-2006 Fleet/Retail/Co. Lease: R
Warranty Start Date: 15-JUL-2006 Modified Vehicle: *
Orig Warranty Date: 15-JUL-2006 Reacquired Vehicle: * Vehicle Export Flag: N
VOC/EOC:
---------1---------2---------3---------4---------5---------6---------7---------8----------9----------
T8265167257 K G A2 27K0008 EJ E AK5L 7EC 5 K9 E F 21U777 4 P3 K2 2 B H
1ZVH8 3 5 140A 9HKNC E
INSTALLED OPTION INFORMATION:
Air Conditioning: C/B - MANUAL AIR CONDITIONER GVW Code:
Alternator Amp Rating: * GVW Class Code: H
Audio Disk: * - [N/A] Instrumentation: * - [N/A]
Axle Ratio: EGAHD - 3.55 FINAL DRIVE RATIO Mirror(Driver Side): AD - DRIVER POWER MIRROR
Axle Type: EGJAC - LIMITED SLIP REAR AXLE Mirror(Psngr Side): AD - PASS POWER CONVEX MIRROR
Battery Amp Rating: B Paint: PN3EF - WINDVEIL BLUE
Brake Code: * -[N/A] Power Antenna: * - [N/A]
Brake Code(Service): * -[N/A] Radio: FC - CDX6+ RAD W/ SP SENS VOL CONTR
Calibration Code: 6ZF2G80A Sound System: AH -SUBWOOFER/AMP. SOUND SYSTEM
Color(Accent): * - [N/A] Suspn Tandem Axle:
Color(Trim): 000EN - MEDIUM DOVE Tire Brand: AK - PIRELLI
Delivery Type: 0 Tire Size: D3KCG - P235/55ZR17 99W A/S
Driveshaft Code: * Traction Control: AB - ANTI-SPIN TRACT BRAKES W/O IVD
Front Seat: C/A - SEAT-SPORT-DRV/PASS Wheel Base:
Fuel Type: AF -UNLEADED FUEL CAPABILITY
TIRE DOT INFORMATION:
LF: N9EKF6613705 RF: N9EKF6613805
LR: N9EKF6613705 RR: N9EKF6613805
LI: * RI: *
SPARE: UY6J_ABC3605
ESP INFORMATION: EMISSIONS INFORMATION:
ESP Code: * Emission Code: DGAAE - DGAAE
ESP Coverage(Miles): * Emission Cert Type: 5
ESP Coverage(Time): * Emission Decal Suffix: NJB
ESP Plan Year: * Engine Family: 6FMXV046VEM
ESP Signature Date:
benderofbows
  • May 19, 2009
Hey, thanks!
Wow, when the original owner said he'd never had any problems with the car, he wasn't kidding. Just one wiring problem and one dead battery in almost three years. Looks like I got a good one! Thanks again
98stangv8
1,036
fayetteville, nc
May 19, 2009
  • May 19, 2009
Hey, are you in NC? Lafayette, Sanford Ford? In the Fayetteville Area?
DStang99
46
Florida
May 19, 2009
  • May 19, 2009
Hello
Can someone run a oasis report on my gt
1fafp42x3xf147899
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
Looking forward to collaborating with my new community
  • phil2001svt
  • Sep 24, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 10, 2026
phil2001svt
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
N
SOLD FOR SALE: H&R Super Sport FRONT springs only, 79-93 Mustang, 51650.77 F
  • nfilut43
  • Nov 2, 2026
  • Suspension Parts
Suspension Parts Nov 10, 2026
nfilut43
N
