  • SN95 4.6L Mustang Tech
OBD2 code P0357 questions
  • Thread starter Thread starter VIRstang
  • Start date Start date Aug 23, 2008
V
VIRstang
67
Cary, North Carolina
Aug 23, 2008
  • Aug 23, 2008
I have a error code, P0357- Ignition coil G Primary/Secondary circuit malfunction on my 99 GT with the 4.6. It occured on a dyno run. I had just installed new Summit coils. The dyno guys said the Summit coils suck and thats the problem. My question is which cylinder is it and should I replace all the coils with better units? Does anyone have a list which identifies on a 99 GT which coil is which letter? I read somewhere that the G coil was the second from the back on the drivers side.
Any help or advice is welcome!
Thanks,
Ben
9
97speedster
134
stanwood,wa
Aug 24, 2008
  • Aug 24, 2008
All Data says that P0357 is a crank positioning sensor.
V
VIRstang
67
Aug 26, 2008
  • Aug 26, 2008
The book that came with my OBDII sensor shows codes between P0335 AND P0339 as a crank positioning sensor problem. Codes P0351 through P0362 are listed as ignition coil issues. I just need to know which cylinder is listed as "G".
Thanks,
Ben
9
97speedster
134
stanwood,wa
Aug 26, 2008
  • Aug 26, 2008
The codes that you are telling me do not match what is listed in AllData for your year of car at all. The P0357 in AllData is for a crank positioning sensor.
blackink00
I missed a shift & stole Curt's money.
Mar 30, 2005
545
Tempe, AZ
Aug 27, 2008
  • Aug 27, 2008
well g is the cyl 7 so that would be second one from back on the driver side. switch the coil with another and see if the problem follows to a different cyl. thatll verify its a coil problem
V
VIRstang
67
Aug 27, 2008
  • Aug 27, 2008
97 speedster,
I'm not sure what Alldata is. I am just going by what is in my OBDII manual and what I found online. I thought the purpose of OBDII was to use the same codes for all cars. Regardless, I recently had the crank position sensor replaced, so its worth looking at. I've just got a slight miss at high rpms.
Blackink00,
Thanks for identifying cylinder "G" for me. I'm going to try that as well.
Thanks,
Ben
9
97speedster
134
stanwood,wa
Aug 27, 2008
  • Aug 27, 2008
ALLDATA is a online code reference guide that tells what each code means for each individual car. Some codes are not the same from year to year. If your book is not specific to just your car it could be very misleading. Check out ALLDATA - OEM Automotive Repair Information and Technical Service Bulletins it is not a free service but it is well worth it.
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
