Odd chirping noise
PeteyAce
346
car makes astrage chirping niose when ever i turn on the heat while driving, but when i step on the clutch the chirping stops, and the faster i go the faster the chirping is, its annoying the crap out of me :stick:
Never heard of that one... Are you sure there isn't a bird in the blower motor? (sorry)
What mode do you have the vent selector in? Does it do it in all modes?
When you unload the engine from the rest of the driveline it stops making a noise... I am stumped.
So the noise only occurs when the HVAC blower motor is on AND the clutch pedal is depressed? That is too goofy.
You should be able to play around with the fan and the clutch pedal while driving to narrow it down.
Good luck.
If the noise subsides when lightly pressing the clutch pedal, I would lean toward the TOB.
If you think belt, you can remove it and let it idle or rev it up (VERY BRIEFLY, on a not hot motor) and see if the noise subsides. I kinda doubt it is the belt.
Good luck.
