Odd fix for backfiring through the carb
  • Thread starter Thread starter hunterhicks
  • Start date Start date Jul 22, 2007
H
hunterhicks
62
D/FW
Jul 22, 2007
  • Jul 22, 2007
FYI for those good kiddies that use the search feature of this site.
I had a really odd problem of backfiring through the carb when I put any load on the engine- you could drive, but you have to very slowly accelerate or POP POP goes the carb.
Edelbrock 600 1406. I totally rebuilt the carb, changed timing, changed rods and jets, you name it. nothing fixed it.
What was it?
The ignition. I had a bad plug/wire/cap/rotor- not sure which, replaced all of them at once, and it is now fixed.
Strange, eh?
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Jul 23, 2007
  • Jul 23, 2007
What was it?
Strange, eh?
It was most likely the cap...there was probably a short that was causing a cylinder to fire when an intake valve was still open.
I had similar behavior when I got some condensation under the cap...I was lucky, I simply dried it off and it worked fine.
It's always a good feeling to solve one of those pesky problems, eh?
D
D.Hearne
11,730
south louisiana
Jul 23, 2007
  • Jul 23, 2007
Nothing odd about it, what often seems like a carb or fuel problem can just as likely be ignition related.
O
oscart
  • Jul 24, 2007
Back firing through the carb often means that the timing is too far advanced. Back firing in the muffler can mean the timing is far retarded. Also, check your firing order and the condition of your wires. In the dark of the night run your car with the hood up and with a spray bottle, mist warm water over the engine and watch for sparks or arching.
D
D.Hearne
11,730
south louisiana
Jul 24, 2007
  • Jul 24, 2007
Thru the carb also happens with retarded timing. If it's retarded enough, it'll hiccup thru the carb when you try to accellerate too fast from a stop
Max Power
1,774
St Paul
Jul 24, 2007
  • Jul 24, 2007
So, when I get a backfire, replace the entire ignition system?
Got it!
D
D.Hearne
11,730
south louisiana
Jul 24, 2007
  • Jul 24, 2007
Yea, but you also need to upgrade the intake and carb too!!!!!! No sense wasting that money.
Bosscat
1,265
England
Jul 25, 2007
  • Jul 25, 2007
What was it?
Strange, eh?
Good info!
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Jul 26, 2007
  • Jul 26, 2007
CARBON TRACKING
its when carbon builds up on the bottom of the cap and creates an easier electrical path to be completed by the ignition system.. then it fires on the incorrect plug... pretty simple sometimes it is very hard to see.. if you still have the old parts look under the cap for a tiny black line that looks similar to a "lightning bolt" shape thats normally the path it would take
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
