So I've been having an odd misfire-like symptom that seems to be getting worse over time and I can't seem to narrow it down. I have an 03 GT with just under 70,000 miles on it and I keep getting a hesitation/jump/misfire every time I seem to hit a small bit of uneven pavement while driving. As far as I can tell, it's not the clutch because my RPMs do not increase and my logic behind that is that if the clutch was slipping or missing, it would allow the RPMs to climb if I was on the gas, but they don't.
When I do get this miss, you feel it inside the car as if I just decided to floor it (although I don't get pushed back in my seat, but rather forward). Sometimes it just "cuts out" for a second, but you can hear that there's a break in the exhaust and other times it can be pretty violent and actually scare the crap out of me. If I just coast over a bump or something that I feel will cause a misfire with no acceleration, nothing happens, although whether or not this symptom would actually happen or not is obviously unknown, but I've tried multiple times.
This started happening after I read all the positive things about washing the engine and decided to give it a try for myself
. However, the wash was a month ago and I only used shower mode on my hose (first and last time, I'm going to use my girlfriends toothbrush from now on) so I kind of feel like there shouldn't be any left over water. At that time I received a code for a misfire on a certain cylinder and it was picked up by the computer as a misfire (the CEL blinked and I was running on four cylinders). I found and pulled a dead coil, got a replacement (and even replaced another one I thought could be on its way out) and that fixed the code and got it running back on all 8. Checked the well for water, didn't see any, but stuck a rag down there anyways for any sort of wetness and even replaced the spark plug on that cylinder ($2 insurance, right?). All seemed fine for about a day and then these random misses started. I do not get any codes and I can't find any sort of issues going on. I haven't pulled all the plugs to check them, but I have pulled most of the coils. I've just been a little busy and I hate driving the car this way, but I have to get to work and back. I'm probably going to dive into it again tonight and wanted to know if anyone had suggestions on where to start with this.
Edit: I did not wash the engine hot. It sat overnight and I washed in the following day stone cold. I also let it sit for a few hours after the wash (I cleaned up and dried it off, obviously, just didn't immediately start it). I used Simple Green as well.
. However, the wash was a month ago and I only used shower mode on my hose (first and last time, I'm going to use my girlfriends toothbrush from now on) so I kind of feel like there shouldn't be any left over water. At that time I received a code for a misfire on a certain cylinder and it was picked up by the computer as a misfire (the CEL blinked and I was running on four cylinders). I found and pulled a dead coil, got a replacement (and even replaced another one I thought could be on its way out) and that fixed the code and got it running back on all 8. Checked the well for water, didn't see any, but stuck a rag down there anyways for any sort of wetness and even replaced the spark plug on that cylinder ($2 insurance, right?). All seemed fine for about a day and then these random misses started. I do not get any codes and I can't find any sort of issues going on. I haven't pulled all the plugs to check them, but I have pulled most of the coils. I've just been a little busy and I hate driving the car this way, but I have to get to work and back. I'm probably going to dive into it again tonight and wanted to know if anyone had suggestions on where to start with this.Edit: I did not wash the engine hot. It sat overnight and I washed in the following day stone cold. I also let it sit for a few hours after the wash (I cleaned up and dried it off, obviously, just didn't immediately start it). I used Simple Green as well.
