  • SN95 4.6L Mustang Tech
Odd noise over bumps
  • Thread starter Thread starter Mach1Run
  • Start date Start date Aug 10, 2005
Mach1Run
333
Wylie, Texas
Aug 10, 2005
  • Aug 10, 2005
Got the mach home and into the garage last night without the radio playing for once, and as I went up the riser that keeps water from blowing under the door there was a sound that came from the rear end. It sounded like rubber squeeking. So I drove around a bit and found the only time I can get it to do it is by going over a hard bump or a quick rise and fall in the road. I cant duplicate the sound by pushing down in the trunk. I'm pretty sure its got to be in the suspension somewhere but dont know what to look at. Im gonna take it to a dealership and have them look at it since its still under warranty but would like to have an idea what it could be in case they try and blow alot of smoke. Any ideas or suggestions?
M
Merbie
60
Between Baltimore/DC
Aug 10, 2005
  • Aug 10, 2005
My car did the same thing. Only, for me, it was the front. I cant remember if we decided it was the tie rod ends or the ball joints, but I just pump grease into the fittings and it goes away. My mechanic (Ford Mechanic) said it is common in Fords Ball joints.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 10, 2005
  • Aug 10, 2005
The dealer will silicone spray the crap outta the rear end suspension components and declare it fixed. You could just as easily do this yourself...
M
Merbie
60
Aug 10, 2005
  • Aug 10, 2005
OH yeah, mine eventually started squeaking around turns. That is when I found out it was ball joints/tie rod ends!
Mach1Run
333
Wylie, Texas
Aug 10, 2005
  • Aug 10, 2005
What kinda of silicone would be best to try? If its something that easy I may was well try it myself before I go to all the trouble of trying to get out to the dealer.
Mossberg
ATL, Shawty
Aug 10, 2005
  • Aug 10, 2005
I have the same issue. I've learned to live with it.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
uh oh that sounds like $$$$$
  • *HOOFHEARTED*
  • Jan 17, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jan 18, 2025
*HOOFHEARTED*
Im baaaack
  • *HOOFHEARTED*
  • Jan 17, 2025
  • The Welcome Wagon
The Welcome Wagon Jan 17, 2025
General karthief
