  • 1994 - 1995 Specific Tech
odd problem-car turning on and off while driving
  • Thread starter Thread starter 1994Vib.RedGT
  • Start date Start date Dec 28, 2006
First Prev 2 of 2
HISSIN50
34
129
Dec 30, 2006
#21
  • Dec 30, 2006
  • #21
Reading the codes can be a real PITA on these cars. One of those LCD readers sounds nice, eh? Got a friend with one that you can borrow?
One caveat is that you sometimes get a real quick ghost flash - it's a separator for the code readers but you're not supposed to pay attention to it. Is this a KOER or KOEO code? What do you get in the other run-mode?
Good luck.
1994Vib.RedGT
585
Denver, CO
Dec 30, 2006
#22
  • Dec 30, 2006
  • #22
yea, i wasnt counting the ghost flash.
but koeo and koer both showed the same thing
1994Vib.RedGT
585
Denver, CO
Dec 30, 2006
#23
  • Dec 30, 2006
  • #23
I checked the black thing by the plastic wheel under the rotor, it seemed to be pretty snug, but as far as I know thats still the original distributor and ****, with 102k miles on it.
HISSIN50
34
129
Dec 30, 2006
#24
  • Dec 30, 2006
  • #24
I periodically clean the PIP - douche it with electronic contact cleaner. You can also run a magnet around inside the bowl. If it picks up ferrous material, the PIP or dizzy bushing are likely taking a poop.
Good luck.
Farmers SN95
76
Ky
Dec 31, 2006
#25
  • Dec 31, 2006
  • #25
My car is do the same thing most of the time when I am give someone ride , I will be driveing the the car and the tach will drop to 0 and the car will shut off, and will come back on, and some time I will be at a stop and the car will shuts off, and not start back , I have let it set and then it will start.
9
94GTPilot
82
#26
  • Dec 31, 2006
  • #26
Hey everyone... I had the same exact problem when I first got my mustang, except I also had the added bonus of the car deciding when it wanted to start and not start. Didn't matter what the temp was, how long it had been sitting, etc. Would even die driving down the road and wouldn't start back up for 5, sometimes 30 mins. Replaced darn near everything I could think of, including the computer, until it finally died about 90 miles from home, and during the tow, the driver told me it was my distributor module (which I'm assuming is the PIP you guys are talking about). Went and bought the wire harness thingy that pokes out of the dizzy, took the dizzy out/apart, replaced it, and haven't had a problem since.. HTH :SNSign:
I
IC5_OH
#27
  • Dec 31, 2006
  • #27
I have been having the same problem with my 94 GT. engine would shut off and stall on the highway, sometimes would start right back up other times I would have to wait 5,10,30, or even an hour before it would fire back up again. I also had the surging problem where the rpms would drop to 0 then fire back up while I was still on the highway cruising. Had the coil changed, still stalled on me, new cap, rotor, plugs still stalled. Sick of the shop I searched around on some mustang sites and many people pointed to the ignition module thats under the air intake on the passenger side fender. It was a 50 dollar part and it took about a half hour to install because I had to go buy a specialty tool to take the module off the heat shield. Anyways hasn't stalled or stumbled on me since I replaced the part. Hope you figure out the problem!
94_Teal_GT
405
Palm Bay, FL
Dec 31, 2006
#28
  • Dec 31, 2006
  • #28
Just an FYI for the original poster....I believe that's the TFI module(used to be on the distributor on older 5.0L). It is possible that it's bad, before buying a new one, take the module to Autozone. They can test those for you, for free. Hope this helps.
HISSIN50
34
129
Jan 1, 2007
#29
  • Jan 1, 2007
  • #29
For anyone whom has the car actually not restart immediately after it craps out:
Check for injector pulsing and spark. If you are missing both, the PIP is likely.
If you have injector pulsing but no spark, the PIP should be ok. Look at the TFI, ignition coil, etc.
First Prev 2 of 2
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
