  • SN95 4.6L Mustang Tech
Odd tire wear
  • Thread starter Thread starter merc123
  • Start date Start date Sep 19, 2004
merc123
420
North GA
Sep 19, 2004
  • Sep 19, 2004
I recently rotated my gatorbacks again and noticed and odd trend with ALL 4 tires. They are all wearing on just the very outside tread of the tire. Is it just from high speed cornering or what? These tires have around 20,000 miles on them. They are also very close to the wear lines as is.
G
GinoGT
1,862
Sep 19, 2004
  • Sep 19, 2004
Maybe you don't have enough air in the tires for how hard you're pushing it through the corners. Not enough air would cause the sidewalls (outer edge) to flex in and put a lot of stress out the outside edge of the tire.
Just a guess.
merc123
420
North GA
Sep 20, 2004
  • Sep 20, 2004
I had 40 in the rear and 42 in the front. Now I lowered them to 35 in the rear and 37 in the front.
M
mrpositraction
296
Columbia, MO
Sep 20, 2004
  • Sep 20, 2004
Check your alignment, it sounds like you have positive camber. I didn't look to see what type Mustang you had, if you have independent in rear, that could be the same case, and cornering hard will also do the same thing. You got a pay to play.
DTMach1
240
Virginia Beach, VA
Sep 20, 2004
  • Sep 20, 2004
definately sounds like too much positive camber...but generally it would only apply to one or both of the front tires...not all four!
Green Flea
28
California
Sep 20, 2004
  • Sep 20, 2004
If you have stock suspension and you corner hard all the time you are going to get outside tire wear because the car has so much body roll. I had the same problem. I wish I would have lowered mine when I first got it, My tires would have lasted much longer.
T
tripsober
217
massachusetts
Sep 20, 2004
  • Sep 20, 2004
it's just the camber, its on all 4 cause i am guessing you rotate them every so often ya know.......... so just get an alighment and air pressure keep around 32 psi 40 is to high
340.29m/s
213
Blue Springs, Mo
Sep 20, 2004
  • Sep 20, 2004
I had my front tires up to about 42lbs for when I went to the track and it DESTROYED the outter edges of my tires. I lowered the pressure in the front tires and swapped them front to back and have had no more issue. I don't know why, but I attribute the wear to too much pressure in the tires.
StangLou
1,264
Holly Springs, NC
Sep 20, 2004
  • Sep 20, 2004
I had something similar to this happen on my '03. Weird thing about mine was that it was only the driver side The very outside edge was wearing badly. I had my shop look at it and one of the guys thought it could be toe, but that would affect both front tires, not just one. Air pressure was at around 32 in front driver side, and 30 on passengers side. With that I would think that the passenger side would show wear on the outside before my side did.
I got the car lowered a week or so after I noticed the tread wear, so I put c/c plates on as well, and got it aligned.
Later I got 2 Nitto 555's put on the back, so I just kept my 2 best tires and put them on the front.
If anyone is in the market for new tires I definately recommend the 555's
M
mrpositraction
296
Columbia, MO
Sep 20, 2004
#10
  • Sep 20, 2004
  • #10
Toe would not cause tires to wear out on the outside (or insides for that matter) mostly odd tire wear is attributed to camber. If your camber was perfect, and you and terrible toe, the tire would wear evenly, I am currently testing the affects of lowering cars right now at work. I will let you guys know the results when I am done. I am measuring tire temperature differences from Caster, Camber, and toe. Fun part about it is I get to use my Stang as a test vehicle which = free parts to me
G
GinoGT
1,862
Sep 20, 2004
#11
  • Sep 20, 2004
  • #11
How? You normally do need more pressure at the track (not strip) because of the forces you're putting on them. If anything, overinflation would cause the middle of the tire to wear faster. Underinflation is what kills the shoulders.
merc123
420
North GA
Sep 21, 2004
#12
  • Sep 21, 2004
  • #12
I'm not sure. I'm going to mess with tire pressures and see. I'm keeping it around 35 and 37 HOT so it will be around 32 and 35 cold. I rotate the tires when I change the oil (5k miles)
Screamin' Demon
204
winchester, va
Sep 21, 2004
#13
  • Sep 21, 2004
  • #13
im running 36 PSi in mine and still have the same problem, so what would be the cure? more or less?
merc123
420
North GA
Sep 22, 2004
#14
  • Sep 22, 2004
  • #14
Wonder if ford can adjust camber under warranty?
N
natx808
35
Honolulu, HI
Sep 22, 2004
#15
  • Sep 22, 2004
  • #15
I think it is a side-effect of driving habits.
At 20k miles the tread was gone on the outside of my front tires. I got new tires and had an allignment done. The allignment was totally within spec!
I had been living near some twisties and was always screaming/drifting through them. I also worked in an office and had to park in a garage. I wouldn't haul ass through the garage but my tires were always squeeling going around the turns down 4 levels of the garage. Type type of driving causes weight transfer to the outside front tire and I believe that caused the premature tire wear. Apparantly this can be resolved with a camber adjustment even with stock suspension setup.
I need to do this adjustment, since I've put 5k miles on the new tires the outside is noticably worn.
merc123
420
North GA
Sep 22, 2004
#16
  • Sep 22, 2004
  • #16
sounds good. I'll have to try that. How much would a camber adjustment be and what's involved
R
Wow, Tire Issue on 2019
  • Rcdgl
  • Dec 30, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Yesterday at 10:51 PM
2014 Mustang GT - Original Pirelli Tires - Dry Rot ?
  • Bhenders
  • May 9, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 25, 2025
SuperCharged_Coyote
G
Expired 2013 Ford Mustang V6 (Grabber Blue) 3:55 gears... Excellent Condition.
  • Grabberblueguy77
  • Nov 19, 2025
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Mar 11, 2026
Grabberblueguy77
G
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
