Odd Turn Signal Issue
  • Thread starter Thread starter Bullitt
  • Start date Start date Dec 23, 2008
Bullitt
Packin' Heat
2,743
Houston, TX
Dec 23, 2008
  • Dec 23, 2008
Did a search before I posted, but couldn't seem to find a similar set of symptoms..
What Doesn't Work:
Driver's side Turn Signal when activated by turn signal switch (on solid)
What Does Work:
Emergency Lights (both)
Passenger Turn Signal (flashed fine with switch).
Parking Lights (both)
Problem is the same irrespective if the headlights are on or not. I've tried new bulbs and no change.
Have cleaned all the connections and made sure they're tight. Could it be the signal unit itself? They're original Ford, but wiring and everything is in good shape.
Any ideas would be much appreciated, thanks!
2nd Mustang
2,488
Southern California
Dec 23, 2008
  • Dec 23, 2008
Check brake light bulb to see if they are being activated when stepping on brake and using turn signals. I seem to remember having that problem when one of the rear lights went out.
Bullitt
Packin' Heat
2,743
Houston, TX
Dec 23, 2008
  • Dec 23, 2008
No luck. Taillights work fine. Swapped in a different (new) bulb and no improvement.
N
Nosboss
115
  • Dec 23, 2008
A lot of the brake/turn signal problems are in the turn signal switch behind the steering wheel. The contacts get old and worn out. I have been lucky and was able to clean mine to fix my brake/turn signal light. You might look into that. The steering wheel has to come off to get to it though.
Tim65GT
1,149
West Texas
Dec 23, 2008
  • Dec 23, 2008
You still didn't say if the brake lights work or not.
But since the emergency flashers work, it's probably the the turn signal switch or connector/wiring in/under the column.
Bullitt
Packin' Heat
2,743
Houston, TX
Dec 23, 2008
  • Dec 23, 2008
Brake Lights do work.
I'll look into the column... Dash / steering wheel are all off the car. Switch is relatively (well, miles wise). Hope it's not that...
Forgot to add: Indicator on the dash doesn't come one for the driver's turn signal...
D
D.Hearne
11,730
south louisiana
Dec 23, 2008
  • Dec 23, 2008
A slow or non blinking signal is due to both the flasher being a light duty unit and/or one of the bulbs in the circuit not working. Install a heavy duty flasher and get a freind to verify all the bulbs are functioning when the signal's on. Also check the grounding of said bulbs
Bullitt
Packin' Heat
2,743
Houston, TX
Dec 24, 2008
  • Dec 24, 2008
D.Hearne,
Have you got a recommendation for a "heavy duty flasher"?
Thanks!
Edster
500
League City, Texas
Dec 24, 2008
  • Dec 24, 2008
I had a similar problem and it was in the column. The original switch was replaced by an inferior replacement. I bought a new one after checking around and that fixed my problem. I think I got it from NPD.
Bullitt
Packin' Heat
2,743
Houston, TX
Dec 24, 2008
#10
  • Dec 24, 2008
  • #10
FIXED!!
Put in a heavy duty flasher module off the generic rack at the parts store. Works like a champ.
Thanks D.Hearne and all those who chimed in!
D
D.Hearne
11,730
south louisiana
Dec 24, 2008
#11
  • Dec 24, 2008
  • #11
Bullitt said:
FIXED!!
Glad to see you figured it out. Flashers have come in two duty ranges for years. I've always used the HD ones. The light duty flashers have always been crap to me. They either flash too fast or not at all if one(or more) bulb doesn't work. The HD flashers also work better than the light dutys when pulling a trailer too.
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
68 horn and turn signals stopped working
  • connella08
  • Sep 10, 2025
Classic Mustang Specific Tech Sep 10, 2025
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
