  • 2005 - 2009 Specific Tech
off idle hesitation?
  • Thread starter Thread starter bad monkeys
  • Start date Start date Oct 28, 2006
1 of 2 Next Last
bad monkeys
135
Duarte, So Cal
Oct 28, 2006
  • Oct 28, 2006
I used to own a 2000 GT, but have since up graded to a 2007. My question is, is there anyway to get rid of the hesitation which takes place from idle to about 2200 rpm? The 3V motor would be a complete work of art if not for this problem. Any help would be greatly appreciated.
Bad67MF
60
Sparks Nevada
Oct 28, 2006
  • Oct 28, 2006
A tune will help, I've heard that CMCV deletes help.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Oct 28, 2006
  • Oct 28, 2006
get a tune!
V8JamesGT
218
Oct 28, 2006
  • Oct 28, 2006
Might as well get an intake when you get your tune. Doug from Bamachips and Brent from brenspeed are GREAT tuners and can give you a good deal on an intake/tuner combo. I went with the JLT Intake and SCT Tuner from Brent and the throttle response is greatly improved and the power is awesome! The price was right too (only $554)!
Jenns01TA
37
Oct 29, 2006
  • Oct 29, 2006
James,
You have an AOD or is it the DBW that was giving you heck?
~J~
bad monkeys
135
Duarte, So Cal
Oct 29, 2006
  • Oct 29, 2006
The car is an 07 GT with a 5spd. The axle ratio says CG which I think is a 3.31 (correct me if I'm wrong). It's a great car but the throttle lag is a big PITA, especially in traffic. Any suggestions would be greatly appreciated. Thanks
V
VegasGT
32
  • Oct 29, 2006
bigcat said:
get a tune!
+1!!!!!!!!!!!!
W
Warlok
89
  • Oct 29, 2006
Quick to rev
I have an 07 GT also. Mine is a 5 speed Manual. I went with Brenspeed.com and bought my SCT Xcal2 tuner and C&L CAI with Pypes stainless steel mufflers at one time. It will make you crazy with the new power and NO LAG any more. Gas mileage will go up as a big plus, but you wont believe the second you blip the throttle the first time.
It turns it into another new car to re learn to drive and enjoy more.
ShowYa06
144
Kansas City, MO
Oct 30, 2006
  • Oct 30, 2006
I was at a dead stop today, light went green and my car nosedived like never before. I had just come off a 60 MPH drive with cruise on for say about an hour. I was like WTF? And never done it again all day Sunday.
Jenns01TA
37
Oct 30, 2006
#10
  • Oct 30, 2006
  • #10
bigcat said:
get a tune!
ski
380
Oct 30, 2006
#11
  • Oct 30, 2006
  • #11
TSB 06-9-9
HESITATION ON ACCELERATION AFTER LONG CRUISE
FORD: 2005-2006 Mustang
ISSUE
Some 2005-2006 Mustangs may exhibit a hesitation on acceleration after a long cruise. After coming to a stop from a highway type cruise, some vehicles may experience a hesitation when the customer begins to accelerate. Air bubbles can form around the fuel pump during a long cruise and be ingested into the pump on acceleration causing a hesitation.
ACTION
Refer to Service Procedure for corrective action.
SERVICE PROCEDURE
1. Perform normal Workshop Manual (WSM), Section 303-04 diagnostics to isolate the concern to the fuel pump.
2. Replace the fuel pump per WSM, Section 310-01.
PART NUMBER
7R3Z-9H307-C
PART NAME
Sender And Pump Assy
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION
(A)060909A
(B)MT060909
DESCRIPTION
(A)2005-2006 Mustang: Replace The Fuel Pump Module (Do Not Use With 9350E)
(B)Claim Additional Labor Required As Actual Time, Or Use SLTS Operation If Available
TIME
(A)0.9 Hr.
(B)Actual Time
DEALER CODING
Basic Part Number-9H307
Condition Code-53
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by “do-it-yourselfers”. Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article.The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates.The most recent information is available through Ford Motor Company’s on-line technical resources.
Copyright „ 2006 Ford Motor Company Online Publication Date April 28, 2006 PAGE 1
bigcat
May 1, 2005
3,015
7200 feet
Oct 30, 2006
#12
  • Oct 30, 2006
  • #12
for a complete copy of the TSBs, check out this link from the StangNet homepage.
http://www.stangnet.com/Tech-Articles/S197-Technical-Service-Bulletins-060923.html
baylor2010
73
#13
  • Oct 30, 2006
  • #13
Ya mines done that but not sure how ford will react to my warrenty I'm sure they'll notice my heads and cams. Might as well step up to the better fuel pump.
R
rdmorrow
15
#14
  • Oct 30, 2006
  • #14
CAI + U/D pulleys + tune. So long to throttle lag.
bad monkeys
135
Duarte, So Cal
Oct 30, 2006
#15
  • Oct 30, 2006
  • #15
If the aftermarket can tune out the throttle lag why can't Ford do it? I guess this is what happens when you loose a couple of billion dollars in one quarter. Call it corner cutting 101...I guess.
Thanks for the information. Who has the better tune...Brenspeed or Bamachip?
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Oct 31, 2006
#16
  • Oct 31, 2006
  • #16
From what I have read, the engineers at Ford detuned the factory setting to appeal to a much broader range of drivers than those of us who prefer instant reponse?
Bit it's just what I read....
ski
380
Oct 31, 2006
#17
  • Oct 31, 2006
  • #17
Ford wants to minimize the amount of warranty work performed on damaged drivetrain components.
R
rdmorrow
15
#18
  • Oct 31, 2006
  • #18
Of the two, my vote would be Brenspeed.
I took mine to a mustang performance shop and put it on the dyno. They tuned it using an XCal.
RD
bigcat
May 1, 2005
3,015
7200 feet
Oct 31, 2006
#19
  • Oct 31, 2006
  • #19
300 hp sounds good, but they want to minimize the amount of abuse they will have to warranty. if they add lag, then its harder to beat on your car.
V8JamesGT
218
Oct 31, 2006
#20
  • Oct 31, 2006
  • #20
Jenns05Stang said:
James,
~J~
Whats AOD and DBW stand for?
If you were talking to me, I had a bad throttle position sensor. It was replaced under warrany and havnt had any problems since!
1 of 2 Next Last
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Monday at 11:07 AM
phil2001svt
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
