  • 2005 - 2009 Specific Tech
Off-road X-pipe question
  • Thread starter Thread starter Parks07
  • Start date Start date Sep 4, 2006
First Prev 2 of 2
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Oct 8, 2006
#21
  • Oct 8, 2006
  • #21
Malfunction Indicator Lamp eliminators. it tricks the computer into thinking the cats are operating normal, even though the are not installed.
Bad67MF
60
Sparks Nevada
Oct 8, 2006
#22
  • Oct 8, 2006
  • #22
Thanks, with these installed then would you not lose any performance? (if you've fooled the computer)
bigcat
May 1, 2005
3,015
7200 feet
Oct 8, 2006
#23
  • Oct 8, 2006
  • #23
never tested it at the track, but the check engine light will NOT come on.
Black2006GT
56
Georgia
Oct 9, 2006
#24
  • Oct 9, 2006
  • #24
The only reason the check engine light comes on is because the computer detects no change in the readings of the upstream (green connectors) and the downstream (blue connectors) oxygen sensors. This is all "after the fact" . . . meaning that this condition alone does NOT affect performance. You'll have a code p 0420 and p0430 in memory for catalyst below effeciency on bank one and two, respectively. The downstream O2 sensors do NOT affect performance. They are for emissions detection only. DarkfireGT stated that he had a code for the front (upstream) O2 sensor. The front O2 sensor is critical for mixture control and will cause poor performance and fuel economy. I had an o/r x pipe with no tune for about a month and I can tell you two things. First, it sounds like crap. Second, it doesn't run a bit different. I have it for sale now because I put on a Bassani catted x pipe and it sounds great. My suggestion is to stick with stock cat h-pipe and change the muff's or stick with stock muff's and change to a catted xpipe. You are not gonna get anY performance gains either way, only a change in sound. I noticed HUGE performance gains with a C&L cai and SCT2 tuner btw
First Prev 2 of 2
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Will a 98 gt off-road pipe fit my 03 gt?
  • Stangman 70
  • Mar 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Mar 27, 2025
89ripper
