  • 1994 - 1995 Specific Tech
Off set Rack and Pinion bushing
  • Thread starter Thread starter aaamoranto
  • Start date Start date Jul 27, 2004
A
aaamoranto
69
Snohomish ,WA
Jul 27, 2004
  • Jul 27, 2004
Any of you guys use one of this on a lowered car( aluminium or polyurethene)? Is there any benefits to it? MM motorsport does'nt recommend this but I have X2 balljoint by Steeda and they sell this. I appreciate any input.
A
aaamoranto
69
Snohomish ,WA
Jul 27, 2004
  • Jul 27, 2004
anybody?
Mrgreen94gt
SIMMA DA NA!!!
448
West TN
Jul 27, 2004
  • Jul 27, 2004
If you already have the X2 balljoint and bumpsteer kit, it wouldn't do you any good.. I've got some polyurethane offset rack bushings on mine, but I can't see that it did anything for it. If anything, you should probably get some standard non-offset rack bushings that are either urethane or maybe even aluminum.
If you dont already have the bumpsteer kit with the X2, it is recomended and would work better than an offset rack bushing.
RIO5.0
6,892
N.H.
Jul 27, 2004
  • Jul 27, 2004
All the offsets do is "straighten" the tie rods....If you look at the rack and see your tie-rods at an angle...then offsets reposition the rack to straighten those tie-rods out...they just rotate or swivel the rack to level things out...least thats what I noticed when I did mine....Im sure MM knows what their talking about as far as using em...
I put the FRPP ones in mine when i lowered it...they're aluminum, along with shorter endlinks to re-set the swaybar....
95GTeee
181
Western CT
Jul 29, 2004
  • Jul 29, 2004
I used the poly bushings in mine and everything is A OK! I did notice that they did straighten the tie rods out. I didnt have to do anything with the end joints. I didnt want the aluminum ones because I didnt want the vibrations of the wheels to radiate up to the steering wheel.
A
aaamoranto
69
Snohomish ,WA
Jul 29, 2004
  • Jul 29, 2004
Thanks for the input fella's. I dont have the bumpsteer but I have that creeking sound every time I turn my steering wheel and bushing I hope is the cure based on things that I've read here.it's a debate between normal or off set bushing. I guess off set due to my angled tie rod. Thanks again guys.
Car Nut
1,176
Snellville, Georgia (Atlanta area)
Jul 29, 2004
  • Jul 29, 2004
I am getting most of MM's Road & Track Kit installed. Prior to buying the parts (H&R race springs, Bilsteins, c/c plates, endlinks, front A-arm bushings, quads, swaybar bushings, aluminum rack bushings, and snubber), I asked MM the same type of questions about bumpsteer and they assured me that if a quality shop installed the parts, I should not ever have an issue with bumpsteer. The aluminum rack bushings move the rack back a small amount and provide more responsive and tighter steering.
Of course, my drop will only be about 1", so there's no excuse for the suspension geometry to be out of whack. A good alignment shop should be able to ensure that the geometry is unchanged and with the addition of c/c plates, a proper alignment is guaranteed. Also mentioned was whether or not I wanted an agressive alignment to which I said "no". Again, MM didn't see any excuse for a bumpsteer issue.
I'll have first hand experience in a little over a week, now that I have an appointment scheduled with T&J.
I'm not knocking Steeda's stuff or anyone that has them. Just wanted to repeat what MM told me which is mostly available on their website.
Good luck.
R
Suspension Bushings for SN95 Steering Rack with UPR K Member
  • Riley Barth
  • Jun 23, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Take a look at my rack!
  • bicknell
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2025
Willybill32
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
