Off the Wall T5 Question
  • Thread starter Thread starter rd
  • Start date Start date Jan 22, 2011
rd
3,316
63
109
Ocean Springs MS
Jan 22, 2011
  • Jan 22, 2011
Has anyone here done a Mustang T5 swap behind a sbc?
This is shunned the c world, but I have a couple of T5's, a four cyl, a turbo coupe unit, and a 5.0 to try.
I think it would work fine behind the mild 350 in my Chevelle and I want overdrive.
Thanks.
M
mwood
177
  • Jan 22, 2011
Few questions you should be asking.
1. what parts would you need? bellhousing/adaptor, crossmember/mount, ...
2. would it hold? is it really the best choice?
3. and most important. will it really be cheeper using the t5? After getting all you need to make it fit, would you be money ahead selling the t5 and getting what you need from a junkyard or ebay?
PS, spoke with someone years ago that put a 400 gto to a t5, so I'm sure it can be done.
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,132
224
Massachusetts
Jan 22, 2011
  • Jan 22, 2011
The t5 isn't a ford only transmission. It was also put in the s-10 and camaro. The camaro bell housing might bolt up, and then you can select which t-5 to use based on specs and shifter location. Input shaft length changes as well, but my point is I'm sure there are parts out there to do this if you don't mind mixing and matching
Camaro t5 in center, s-10 t5 up front
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jan 23, 2011
  • Jan 23, 2011
This. Ford didn't make the T5, Borg Warner and/or Tremec made/makes the T5, so it's not exactly a bastard swap. Just have to find the right parts to make it work.
castine917
126
Wyoming, Mi.
Jan 23, 2011
  • Jan 23, 2011
yeah, camaros had t-5s for years also.
rd
3,316
63
109
Ocean Springs MS
Jan 23, 2011
  • Jan 23, 2011
I have heard the it won't hold up stuff, and such. Since it is going in my awesomely overpowered 66 Malibu, currently a high 16 second car, mild 350 with a th 350, and can be driven normally, it will work fine. The tko or t56 kit route is not in the budget right now. One of those two also needs tunnel surgery, not on the agenda until the floor pan replacement.
The plan is to buy a repro 621 bellhousing, pedal and linkage kit. Or a six cylinder Sagninaw setup. his should fit any number of c trans. However, Muncies and such seem to be pricey and still dont get od.
Was looking for some info on the bearing retainer fit, input shaft length, and pilot bearing, etc. So far the S10 unit seems the best choice, but I already have the other 3. Looking for the description of the "right parts to make it work."
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,132
224
Massachusetts
Jan 23, 2011
  • Jan 23, 2011
Unfortunately you might have to find a chevelle board for those answers.
You can always build a hybrid t5. Swapping the internals around is fairly easy. Can always do a stronger mustang gear set, using the s-10 mainshaft and tail housing. Or maybe an aftermarket gearlpset?
But in terms of input shaft length with a chevy engine and bell housing, I'm not sure a whole hello of a lot of mustang guys here have that experience
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Suspension SetUp
  • 23Newb
  • Jul 29, 2023
  • 2.3L (N/A & Turbo) Tech
  • 2 3
7K
2.3L (N/A & Turbo) Tech Sep 4, 2023
23Newb
