Skud said:I tok my '02 GT w/ 16,000km in today. I had them do an oil change, look at the tranny, and some suspension noise.
Didn't take them long to do everything. They also said they couln't get the tranny to do the "crunch". They did say that ford has a bulletin to lower the fluid to 3.2L, which they did. I guess I'll see if it helps at all.
I think Im going to go for a ride with the tech when I go to pick it up. I'll see if I can show them what the tranny does.
Riley
BMan5150 said:Please ask them what "Bulletin" they are referring to. My understanding is that the recommendation to lower the tranny fluid level came from TTC/Tremec, not Ford. It's also my understanding that the official word from Ford on the fluid level is 4 quarts (this from the TSB regarding cold gear clash) yet my manual states something different!
Please ask them what bulletin they are referring to so we all can find out more about this. I'm really not aware of any Ford service bulletin that tells the techs to lower the fluid level.
Mustang225 said:Unfort it appears that Jon Vieth's hands are tied right now.
It's up to us to force the issue with Ford or wait for the TSB to be issued as Jon feels it should be within the near future.
brianmef said:I wonder if we all sent a complaint to the address below, or called the 800# if they would finally realize that this is really an issue with this transmission that needs fixed? If they got thousands of letters or calls, maybe they would quit ignoring this. When you spend $25,000.00+ for a car, it should shift smoothly. If it's 30 degrees out or lower mine just grinds the piss out of the gears when I shift from 1st to 2nd, and I'm not doing anything wrong. I have found that if I take off in 1st and shift into 2nd below 10mph, it don't do it or do it as bad. But you can't hardly do that if you are trying to pick up speed quickly to get into traffic.
Ford Motor Company
Customer Relationship Center
16800 Executive Plaza Drive
P.O. Box 6248
Dearborn, MI 48121
1-800-392-3673 (FORD)
Twisted said:That is the key now. A simple grind will be overlooked, FUBAR or inoperatable transmission will have to be addressed and replaced. Replaced with another potentionally bad transmission.
What happens when you are on your 5th or 6th and now are out of warranty?
