  • SN95 4.6L Mustang Tech
Oh Dammit. . .
  • Thread starter Thread starter Back in Black
  • Start date Start date May 5, 2010
Back in Black
Don't feel bad. Almost 3 years on here and the onl
128
Pittsburgh.. Ford salesmen at Woltz & Wind For
May 5, 2010
  • May 5, 2010
Well, I don't know what happened now but I started my car up today, and before I put it in gear the motor started to miss and heard a large tapping sound. My check engine light is on and its got a large miss all the way through and car wont go over 10 mph. .. .
any ideas?????
trinity_gt
3,125
81
99
Canada
May 5, 2010
  • May 5, 2010
You might have blown a spark plug out.
Back in Black
128
May 5, 2010
  • May 5, 2010
I pulled all the plugs on the coils one by one and noticed a bigger miss with one unplgged. Thanks I will check it. Is it possible it came out of time?
Back in Black
128
May 5, 2010
  • May 5, 2010
I just found out my mechanic adjusted the throttle stop screw on the throttle body. . .that wouldn't have anything to do with it? It was tightened a bit to put the idle at 900. It was a 700 before cause of the break in tune with these cams and wanted to shut off
Back in Black
128
May 5, 2010
  • May 5, 2010
the noise I heard sounded like something in the head loose. It has done this before but straightened right back out
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
May 5, 2010
  • May 5, 2010
Pull the codes and report back. There are alot of sounds that are normal in the engine that tap. I heard an Explorer w/a blown spark plug. It sounded like a loud exhaust leak w/metallic tapping.
Back in Black
128
May 5, 2010
  • May 5, 2010
Yeah it sounded like a marble bouncing around
LI98GTStang
1,715
L.I., NY
May 5, 2010
  • May 5, 2010
Don't mean to scare you. Does it sound like this vid? Spun bearing?
YouTube - 99 Mustang GT 2 Valve Rod Knocker
bhuff30
6,037
35
129
Olathe KS
May 6, 2010
  • May 6, 2010
A rod bearing noise would be more obvious when the engine is hot. It would most likely be completely silent when you start the car, but once the oil is up to temp, at around 2000 rpm light load, it would be scary. Also, you wouldn't normally have a miss with a rod bearing.
Again, pull codes. The computer is telling you something, probably important, so listen to it. I wouldn't be surprised at all if it was something simple as a bad lifter.
Back in Black
128
May 6, 2010
#10
  • May 6, 2010
  • #10
I've been thinking of that. I just gotta get a code scanner to it cause i cannot take it anywhere. Let's see tonight!
salprint
39
Long Island, New York
May 6, 2010
#11
  • May 6, 2010
  • #11
This might sound stupid to some of you gearheads out there, but to me it seems like it could just be a hung valve. I've had that happen (not with the new Mustang) but with older cars when I went to move them from the garage out to the driveway and didn't give the oil enough of a chance to heat up. The next time I went to start it, a valve would hang, (sticky) and I'd have a miss and no compression in that cylinder. After it warmed up, the problem would go away. I've had that happen with a Chevy engine, a ford engine and a Toyota engine. Needless to say, I don't just move a car anymore without giving it 5 minutes of running time before shutting it off.
d98gt
4,505
59
204
SE Texas
May 6, 2010
#12
  • May 6, 2010
  • #12
I wouldn't suggest putting the car under load until you pull the codes to see whats going. That will allow us to eliminate certain options.
Back in Black
128
May 7, 2010
#13
  • May 7, 2010
  • #13
I'm thinking it could be that cause I did have a lifter sticking before . I didn't get a chance to pull the codes yet so I'l try Saturday. I don't even have 5000 miles on this engine build either. It's still on the break in tune so everyting is completly fresh. I do thank all of you for the imput so much. I'm gonna check tomorrow to see if it blew a plug outta the head too. It sucks having to work and have no garage lol
Back in Black
128
May 10, 2010
#14
  • May 10, 2010
  • #14
Well I checked the Code, It said misfire in Cyl 3. . .So I changed the coil, and the plug and yes I did have the correct cylinder lol. . .But the miss and code are still there. . .
Stark77
501
Tallahassee, FL
May 10, 2010
#15
  • May 10, 2010
  • #15
Pull the heads, sounds like it could be damage from PTV.
Back in Black
128
May 11, 2010
#16
  • May 11, 2010
  • #16
From the wha???
R
rockyracoon
874
27
49
margate NJ
May 11, 2010
#17
  • May 11, 2010
  • #17
before you pull the head,why dont you run a leakdown test on that cylinder,that should tell you a lot,in regards to what is going on there,heck even a compression test would be helpful,IMHO.
M
mineralgraygt
187
nj
May 11, 2010
#18
  • May 11, 2010
  • #18
you might have a lifter issue. it might not be pumping up and that what could be causing the miss
Stark77
501
Tallahassee, FL
May 11, 2010
#19
  • May 11, 2010
  • #19
If you take off the valve covers, you can at least get an idea if anything in your valvetrain is bombed. If it all looks good, then you need to dig a bit deeper.
Back in Black
128
May 12, 2010
#20
  • May 12, 2010
  • #20
I'm praying for the lifter. Trick flow was nice enough to send me a new one just in case this was the problem. As soon as it stops raining here one day I'm going to check it out. I put a steathascope on the valve cover and it all sounds normal through both covers on each cylinder.
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
Car won’t start
  • JLB
  • Nov 15, 2025
SN95 4.6L Mustang Tech Nov 15, 2025
nickyb
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
