OH GOD HELP ME
  • Thread starter Thread starter gt500lw
  • Start date Start date Feb 19, 2006
gt500lw
18
  • Feb 19, 2006
My car sucks right now. When I start the car, it dies automatically. This will continue on and on. The only way to keep it running is by using the throttle. Sometimes when it warms up it will run by itself. I upped the idle and that worked for a while, but then it started ideling high. I turn the idle down and it works for a while, then starts messing up again. Also my gas mileage is horrible. I am getting, on this tank, 35 miles on half a tank. That blows. The performance has not been effected.
The first time it did this I took it to a mechanic. They found vaccum leaks in the throttle body (fixed), EGR (fixed), and TPS (fixed). They also said the MAP sensor was out of tolerance. I switched it with another sensor, no change. I am lost. I don't know what the hell is going on. Please help me fix my car. Thanks.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Feb 19, 2006
  • Feb 19, 2006
What year is your car? Do you have an IAC valve (or IAB valve). I'd check that. If it's acting up .... try taking it off & cleaning it with TB cleaner. You can test the electrical side of the valve .... but I don't know what the specs are supposed to be.
HISSIN50
34
129
Feb 19, 2006
  • Feb 19, 2006
I am with Justin. Pull the codes and then go through the process of cleaning the IAC. It sounds like you are running with no IAC and keep playing with the static idle setting, which wont fly (if you are an old timer, it's like trying to run a carbed car in the cold with no idle enrichment).
There have been enough things done to the car that I would not comment further without more info.
Good luck.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Feb 19, 2006
  • Feb 19, 2006
x3 for the IAC
I've also had the battery wire to the solonoid get corroded and eaten through... caused the same problem.
Modular2v
3,222
23
99
oklahoma
Feb 20, 2006
  • Feb 20, 2006
iac
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 20, 2006
  • Feb 20, 2006
peeps never seem to clean there TB. this junk works it way into the iac. just remove it and clean it with TB cleaner.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 20, 2006
  • Feb 20, 2006
See the sticky "Help me create the Surging Idle Checklist" at the top of the forum for help with your idle problems. The first post in the sticky has almost all the details you need.
gt500lw
18
  • Mar 1, 2006
I took off the IAC and cleaned it. Reset the idle properly, set the TPS. I cleaned the battery posts again and found that the positive post was pretty dirty again, only after a month. We'll see. The kick in the head is that two days before I reset everything, it started to idle on its own again. I will let you know how she is working. Thanks for the input.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
