My car sucks right now. When I start the car, it dies automatically. This will continue on and on. The only way to keep it running is by using the throttle. Sometimes when it warms up it will run by itself. I upped the idle and that worked for a while, but then it started ideling high. I turn the idle down and it works for a while, then starts messing up again. Also my gas mileage is horrible. I am getting, on this tank, 35 miles on half a tank. That blows. The performance has not been effected.
The first time it did this I took it to a mechanic. They found vaccum leaks in the throttle body (fixed), EGR (fixed), and TPS (fixed). They also said the MAP sensor was out of tolerance. I switched it with another sensor, no change. I am lost. I don't know what the hell is going on. Please help me fix my car. Thanks.
