Ok so let me start off by saying this is my first post but i am very familiar with forums and such and let my tell you i have searched countless forums on how to fix the turn signals on a foxbody.. So, i am going to start yet another thread woohoo for the same thing AGAIN, because after going through all the steps and the whole process of diagnosing what the problem is, i have yet to find out the issue.. this is what i have done so far to try and figure out my cars issue:
I have replaced the turn signal flasher as soon as i got the car some months ago as that was the easiest.. and yes it does have 12v power going to it.. has 12v power at the fuse panel as well. So i looked over the wiring going to the multifunction switch, and decided it was ok, so big mistake I decided to grab a set of security bits and tear open the switch, and to my surprise it was quite complicated inside and while i couldnt find anything wrong with it, but i also couldnt get it back together (oops).. so I bought a brandspankin new multifunction switch from lmr for a pretty penny (130$) and because it was a 87-89 switch it costs nearly twice the amount as the 90-93 switch ($70, explain that one to me..) anyways I installed it made sure all the wiring for the turnsignal plug was correct via wiring diagrams from forums, and they still dont work... bummer. anyways the hazards work flawlessly so thats not a problem, and when the hazards are on and i flip the turn signal switch it actually makes just the left signal flash no matter which way i flip it.. i dont understand that, and its the same thing the old switch was doing. So to my understanding, after all that they should be working fine but they do not, any help as to why would be helpful, thanks.
