S stng94 New Member Mar 24, 2004 104 0 0 St. Pete, FL Jul 16, 2004 #1 Jul 16, 2004 #1 I didnt check my oil for a while. I just went to change it...pulled the plug and only got 2 quarts. Any thoughts. ??
D DJiCE Member Apr 2, 2003 117 0 17 Bloomfield, NJ Jul 16, 2004 #2 Jul 16, 2004 #2 Did you happen to pull the second drain plug? to the rear of the oil pan... should be close to 5 quarts give or take 1 quart depending on oil consumption..
94TURBO5 O New Member Mar 14, 2004 2,509 0 0 VA Jul 16, 2004 #3 Jul 16, 2004 #3 Yeah the second plug is on the bottom of the pan.
yellow5.0cobra Founding Member Jul 25, 2002 2,849 0 0 In the garage, On the floor. Jul 17, 2004 #4 Jul 17, 2004 #4 yup just like they said... theres 2 plugs! one in the front and one in the back. goodluck! pete
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Jul 17, 2004 #5 Jul 17, 2004 #5 can you tell us where the level on the dipstick was before the change?
VIPERn94Five-0 Founding Member Apr 28, 2002 3,352 2 58 Poughkeepsie, NY Jul 17, 2004 #6 Jul 17, 2004 #6 make sure you got both plugs...your low oil dummy light should have kickd on with just 2 quarts in there..... Anthony
