Oil Change
  • Thread starter Thread starter Funhog
  • Start date Start date Oct 3, 2005
Funhog
219
Alabama
Oct 3, 2005
  • Oct 3, 2005
I was changing my oil and I realized after putting in just over a quart I forgot to drain the second drain. So I emptied both drains. Will just under 5 quarts be enough for the stang? Also, as I was changing the oil I noticed some black residue on the drivers side tie rod and K-member. Any ideas what that is and where it is leaking from? Thanks
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Oct 3, 2005
  • Oct 3, 2005
4.5 quarts would be good enough to get you to the parts store to finish adding the rest of your oil.
The black stuff on your tie rods is probably just road grime. Still better look for leaks in all the usual places though
maverick0716
3,924
Chilliwack, BC, Canada
Oct 3, 2005
  • Oct 3, 2005
The second hump only hold about 1/2 quart at most.....you actually don't have to drain it if you don't want to.
J
jaackal
402
NJ
Oct 3, 2005
  • Oct 3, 2005
check to make sure your oil filter isnt leaking either and the gasket is off the block
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine How does oil make its way into the front sump?
  • Sock_Monke
  • May 10, 2025
Fox 5.0 Mustang Tech May 22, 2025
Chuckster101
C
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
