Oil changes.... how often?
  • Thread starter Thread starter ufnavy06
  • Start date Start date Jan 22, 2008
1 of 2 Next Last
ufnavy06
292
Jacksonville, Florida
Jan 22, 2008
  • Jan 22, 2008
How often do you guys change your oil and how often does Ford actually say to? I know I'm lazy for not walking out to my car.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Jan 22, 2008
  • Jan 22, 2008
the manual says 5000 miles. i change it at 3000.
A
ARTTII
272
Detroit, MI
Jan 22, 2008
  • Jan 22, 2008
Yeah, Ford calls for 5k interval. I do follow exactly that, as I drive a LOT with a lot of those miles being highway. So that works out to an oil change every 3 months (or less) and I'm comfortable with that.
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Jan 22, 2008
  • Jan 22, 2008
I change mine every 5K with Mobil 1 Synthetic and Motorcraft filter. That happens about every 2 months for me.
T
The Fang
602
Tallahassee Fl
Jan 22, 2008
  • Jan 22, 2008
every 3k cause you can tell the oil starts to break down at that point and is pretty dirty by that time.
Art161
130
San Francisco
Jan 22, 2008
  • Jan 22, 2008
For you low mileage drivers, change the oil at least every 6 months, even if you have not gone 5k miles since the last change.
Mark25
93
Virginia Beach, VA
Jan 23, 2008
  • Jan 23, 2008
Every 3k miles (or 6 months)...whichever comes first.
PUNISHER RACING
1,124
FORD CITY, PA.
Jan 23, 2008
  • Jan 23, 2008
I change mine every 5,000 and use the Motorcraft Semi. w/ the 820 high performance filters
xtweakerx
411
Jupiter,FL
Jan 23, 2008
  • Jan 23, 2008
i change mine between 4,500 and 5,000 miles.
Holy crap Kool dawg, u change ur oil every 2 months? lots of driving eh.
O
o0Dan0o
485
#10
  • Jan 23, 2008
  • #10
No crap, thats 30k a year! How often do you buy new cars?
Dan
GOLDENPONY
1,503
LOVELAND, OHIO
Jan 23, 2008
#11
  • Jan 23, 2008
  • #11
OIL
I use Mobil 1 5W20, change it @ 5K miles. If I used dino oil, I'd change it @ 3K miles. Oil's cheap, engines aren't.
kooldawg6
Aug 31, 2006
1,679
Central VA
Jan 23, 2008
#12
  • Jan 23, 2008
  • #12
My '98 Jetta I bought new in '99(has sat since last November)has just over 170K miles. I bought the '06 the very end of last August and have nearly 40K miles on it now It was not intended to be my daily driver, but it is so much more fun than the 90 HP Jetta These are the last two cars I've purchased. I intend on keeping the Stang on the road as long as I can with no concern about racking up the miles
steedman07
176
Connecticut
Jan 23, 2008
#13
  • Jan 23, 2008
  • #13
Im changing mine every 5k..mobil 1 synthetic..Should i go shorter intervals with the Vortech? It uses the oil too obviously..
xtweakerx
411
Jupiter,FL
Jan 24, 2008
#14
  • Jan 24, 2008
  • #14
i've had my car for almost a year and i have 8,500 miles.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jan 24, 2008
#15
  • Jan 24, 2008
  • #15
I change mine every 3000 miles... Mobil 1 5w20, motorcraft filter.
PUNISHER RACING
1,124
FORD CITY, PA.
Jan 24, 2008
#16
  • Jan 24, 2008
  • #16
I had mine from June to Nov. then put it in storage and I put 7,200 miles on it.
red05bullitgt
861
Pittsburgh, PA.
Jan 24, 2008
#17
  • Jan 24, 2008
  • #17
Art ! I put less than 5K miles, per year on my 05GT. I also use Mobil 1 along with the Mobil 1 extended performance oil filter.
So my question is..Would it be safe to change my oil, every 12 months. Or would you still recommend changing the oil, every 6 months.
walter
1,054
Houston TX
Jan 24, 2008
#18
  • Jan 24, 2008
  • #18
For the First 10K miles I changed it religiously every 3K miles to ensure proper breaking in.
now that i'm approaching that 10K mile mark I'll be changing the oil every 5K miles with my trusty Mobil 1 Supersyn and a Motorcraft filter.
Art161
130
San Francisco
Jan 24, 2008
#19
  • Jan 24, 2008
  • #19
If still under warranty, you might not be covered for engine damage if you do not change your engine oil at least every six months.
In any event, if you do not put much mileage on the car, you are probably accumulating water, acid, and other nasty things in the oil. Synthetic oil is no better than dino oil when it comes to oil change intervals for low mileage drivers.
red05bullitgt
861
Pittsburgh, PA.
Jan 24, 2008
#20
  • Jan 24, 2008
  • #20
I forgot to mention, that I change my oil. just before putting it away for the winter. Once it's in storage, I neither run or start the engine. Until the following spring, usually around mid April.
If I'm not mistaken. Fresh oil normally doesn't accumulate water, acid or become dirty from just sitting in the oil pan. IMHO it's really no different, when compared to oil sitting on the shelf for 6-12 months or longer.
I guess under these circumstances. I assumed, that perhaps it might be safe to change my oil, every 12 months..instead of every 6
1 of 2 Next Last
A
How DO you adjust the windshield washers on a 1999 Ford Mustang? Read the old posts about this -
  • apple99Mustangdude
  • Apr 3, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 4, 2026
Engine What’s that?
  • PonyGTrider
  • Aug 24, 2026
Fox 5.0 Mustang Tech Aug 25, 2026
PonyGTrider
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
