So I've been doing my research on this and I can't seem to find anyone who's found a solution to this problem just band-aids. Problem is I'm consuming about a quart of oil every 100ish miles. (yeah, it's alot) & 3 wet plugs.
stock 1988 HO5.0 motor (70k miles) w/1996 explorer intake, plugged egr hole in lower (Sectioned plenum 2" to fit application) , elbow and tb, rebuilt GT40 heads w/roller rockers (baffle cut for RR)
It only smokes if I rev the engine up in park or when I'm driving and let off the gas on high vacuum decel. I immediately do a leak down test that showed less than 10% leak down per cylinder. I checked my line from the tb to the vc and it is clean. I swabbed it with a que tip and it had some residue but nothing crazy.
On to the PCV. It has a new PCV so I checked the line from it to the intake and it seems to be pretty clean (swab came back with just some light residue.
I'm thinking well it HAS to be valve seals, even though the heads were just rebuilt, maybe something was over looked. I pull the intake and it shows quite a bit of oil has been in there, the gasket between the upper and lower intake was wet on the "back" side. I get to the valve seals and a lot of them were sliding up and down with the valve. I'm thinking BOOM there lies my problem.
I changed all the valve seals, start it up and do some quick revs after it warms up and seems to have cured my problem. I get on the FWY and let off the gas to exit while looking in my side mirror and sure enough, here comes the smoke... I drove it around for about 20 miles, came home and checked my dipstick and yes it's burning oil.
HOW am I burning oil? I'm stumped and lost at what more avenues to check? Any help is MUCH appreciated.
