Oil consumption with Trick Flow intakes ?
I'm wondering if the lower intake with my TFS Track Heat has the baffle built into it like a stock lower does. I never used a drop of oil when it was stock. I have the same block and pistons so it can't be my rings. The block has 31,000 miles on it which as you know is nothing. The intake has to be using it somewhere. I'll have to check that when I do the cam.
