oil cooler
i was wondering if it would be worth it to put an oil cooler before my sc? in other words, run the oil line from the place where the pressure sending unit is, to a cooler in the front of the condensor and then to the sc?
id like to cool the s/c so it lasts longer and hopefully if its cooler, it wont heat up the air so much. is it worth doing or no?
But you don't want to route the hoses like you're suggesting. Order the universal cooler from Ford Racing for the 5.0. It'll come with a sandwich adapter that screws on before the filter -- your in/out lines will attach to the adapter. If possible, mount your oil cooler down low where the hot air coming off of it WILL NOT flow back across your a/c condenser or your radiator. Most folks mount the cooler in front of the radiator -- that just puts all the heat from the oil right into the coolant. If you'd like to see pics of mine mounted at an angle down low where hot air off of it flows UNDER the car, email me at [email protected]. The FRPP unit knocked my oil temps from 250-270F down to 210-230F.
