Oil filter splitting on early 4.6
mikeescott
What would cause the oil filter to split on an early 4.6 in a '93 Marquis? It did it about 3 months ago when I started it after work and it did it again when I started it to go to work this morning. It has a small oil leak between the valve cover and oil filter that I have not tracked down yet and it has around 175,000 miles on it. Any help here would be greatly appriciated. Thanks
Reasons: cheap oil filter, to heavy of oil(weight) or a stuck pressure relief valve in the oil pump.
now way-back in @1997 FoMoCo had a TSB about oil filters "ballooning" because people were using oil that was to thick/weight, you should never use anything greater than 10W30 in a Modular engine.
On the road again
The Wix filter did not split. It mushroomed out and the seal popped. I now have a Motorcraft with Motorcraft semi synthetic 5W20. I had used some new 20W50 from my '66 F100 in with the 10W30 last time I changed the oil and I think that was the problem. If it happens again, the motor is coming out for a rebuild and new pump. Thanks for the help.
