Oil in antifreeze
TOM B
Nov 15, 2002
872
Harrisburg Pa
Got oil drops in antifreeze. started to show up in mid summer. Engine has new Edelbrock O ring RPM heads, sent heads back and Edelbrock said there ok.
No antifreeze in oil.
Need help here please. I will take heads off again if nessesary.
I would suspect a bad head gasket or one that is upside down, letting exhaust blow into the cooling system. If you take the cap off the radiator and smell exhaust thats a good indicator.
I did a compression check and a leakdown test and it still did not tell me that I had an improperly installed head gasket on my 351M motor. It wasn't until I took the heads off that I found an upside down gasket.
I assume you replaced your head gaskets when you re-installed your heads. Did you completely flush your cooling system afterward? If not, you may have solved your problem and don't know it. Make sure your system is flushed clean then recheck..
