I need help, this car is going to be the death of me. I had water leaking in my coolant which i suspected to be my timing cover since i had removed the bolts to install my power steering pump. OK, that is a real simplified version of all the hassle I have been through in the past months with this car but anyways here is the point I am at now.
Uploaded with ImageShack.us
See if you can guess which one is my coolant and which is the oil....Really doesnt matter cause the coolant shouldnt look like either of them. What could cause this besides a cracked block? I really dont think my block is cracked. My coolant didnt look like this right before I changed the timing cover. I dont know why on the first test drive this is what it would look like...
I also have tons of leaks everywhere, and everything is new...new water pump, new radiator, new radiator hoses. All my radiator hoses leak out the clamps and the clamps are on as tight as possible. The water pump has a tiny drip right on the bottom. My oil pan is also leaking in the front, I had a one piece oil pan gasket that ripped so I had to cut it and replace the front part with the crappy cork and rubber ring. My oil sending unit is leaking oil. I dont know what else to do, I have taken this motor apart so many times and put it back together with new parts.
The only thing that is left is the timing cover, could a timing cover with an uneven surface cause this? I am about to buy a new timing cover.
