I dont know much about ford engines yet, but I can tell you that GM engines have done this for years. The throttle body usually has a hose attached to it that runs to your heads, what it does is takes all of the smoke and pressure created by your engine and circulates it into your intake to be burned, so you don't have smoke pouring out of your hood somewhere. the pcv valve is just a check ball inside of that system. Some people put a "catchcan" in line with that hose, so the oil will drop into the can, and not get up to your intake. Hope this helps.
