My stang leaks oil everyday as soon as I get home. It's a constant drip after I shut it off but then it stops after it cools. I have a minor rear main seal leak and a minor oil pan gasket leak but it seems to be coming from above the starter, below the #4spark plug area. There is oil on the passenger side o2 sensor and wiring, starter and bottom of #4 spark plug boot. The rear of the intake looks dry, valve covers look dry as well, could it be head gasket or cylinder hole? If it is cylinder hole, will a new set of heads fix the problem. I currently have stock ones. I did have a tranny swap 2 months ago, if it helps, but seal is good.
sorry no pic.
sorry no pic.
