Thanks....I thought it was the oil seperator but I was not sure....I believe this is my problem for sure, it is pushing it out of the oil filler cap too. The oil is turning black even after an oil change. I figure the excess pressure in the engine is pushing the oil into, normally, unused places for oil, causing the oil to become black and dirty. I use mobil one, fyi.
Is the PCV supposed to flow from the oil seperator to the pcv valve to the intake? The hose that goes to the small part of my PCV valve has alot of vacuum, is there supposed to be vacuum on the PCV valve?
