so i have been noticing oil spots in my driveway. just little tiny ones, maybe about an inch diameter. I crawl under there to look, becasue last time i changed my oil i did it myself. i thought the bolts were loose but they werent, and i could follow the path all the way up to my water pump. where the lower radiator hose connects to it there seems to be a bolt that is inbetween the pump itself and the block. the gasket i could see behind it wasnt seated to it, meaning it was almost touching the block, and i could see a drop of oil waiting to fall on that bolt. underneath the car there seems to be tons of places where i can see dirty oil, all around my oil pan prettymuch, my valvecover gaskets, and now the water pump. im going tuesday to get my oil changed and im gonna see if they can see what is wrong with all the oil im dripping, and where its coming from. do you all have any sugestions? im pretty sure i cant change a water pump gasket or valve cover. so throw me some advice. thanks guys.
edit. oh and its been close to 2k miles since my last oil change.
