oil leaking on headers and burning?
thanks for the info srtthis. But what about the oil dipstick? i heard that it is bent wrong, that it can flow out of the top. i need to figure out this oil leak!!!! Its whenever im running through gears and shift at about 5,000 RPMs.
Also i forgot to add, you cannot just slide it down the tube... you have to kinda help it and give it some pressure to get it to go down, could my tube be all messed and is F'*ing everything up?
your going to need to push some but not a lot. should more pretty easily
Man, If you're pushing the dipstick out at high rpm, like someone else mentioned, you've got a crankcase pressure issue. This can come from excessive wear of rings causing blow by, or a plugged up pcv system. You can also get it when running a bunch of boost, but I'm gonna go out on a limb and guess you're not doing that.
You can replace the dipstick tube, but after you pop that new dipstick out, just go a head and tear that thing down and re-ring it. Been there, done that...
How hard is it to re ring it?
1. Pull engine
2. Tear engine down.
3. Check crank and cylinder bores for wear, machine if needed.
4. Remove rings from pistons and install new ones. (Replace pistons if needed.)
5. Slap new bearings in.
6. Install engine.
No big deal...
