Ok, so I changed the spark plugs on my daily driver on tuesday. When I pulled them, I noticed most of them had oil on them. Some had quite a bit more then others. The motor has about 92000 miles on it. A picutre of the plugs is available here:
http://i53.photobucket.com/albums/g68/300zeex/plugs.jpg
Yes there are only 6 plugs. This is on my 2000 V6. I'm posting here because I'm quite sure you guys can give me excelent advice.
I have already had to replace the rear main seal on this motor because it was leeking. I am concerned that the rings had excessive wear between the time that I noticed the oil leek and the time I was able to fix the seal. I added oil to it as often as possible but the leek was rather severe and for the 3 or 4 days before I actually changed the seal out it was pointless to add oil to the motor because it would almost instantly leek out anything over 3 quarts.
My next step is to check the compresssion on the cylinders, but I've gota get a compression tester before I can do that. I have also noticed white smoke on startup, altho not all the time, which started about a week or two before I changed the plugs.
Any advice on what this sounds/looks like along with what else I should be doing/looking for would be most appreciated.
Edit: Forgot to tell you guys that I was 1 quart low on oil as well.
