  • SN95 4.6L Mustang Tech
Oil on spark plug
  • Thread starter Thread starter squeak_cg
  • Start date Start date Mar 10, 2007
squeak_cg
153
Lima, OH
Mar 10, 2007
  • Mar 10, 2007
Hey guys,
My brother got a 97 mustang a month ago or so and it has a 98 Cobra motor in it w/ 80k on it. He got a check engine light and pulled the plugs. Found that one had some oil on it, causing it to miss. Cleaned it up and it runs okay. Any ideas on what would cause this or what to look for? Thanks for any input.
Adam
40th GT
916
Lawrenceville, GA
Mar 10, 2007
  • Mar 10, 2007
You should do a leakdown test and if the leakdown is too high, it's a sign that you're piston rings are worn. The oil could be leaking through the rings and onto the plug.
R
Red2000GT
2,450
Regina,Sask.Canada
Mar 10, 2007
  • Mar 10, 2007
Valve seals are rumoured to be a problem on the older 4-valve engines.
the98stang
2,408
Clovis, CA
Mar 12, 2007
  • Mar 12, 2007
Yea it's most likely the valve cover gaskets. If the rings were shot oil would be all over the spark plug threading. Plus the car would burn oil, spit out blue smoke, and run like sh1t. Check the valve covers.
Door wire harnesses 1996 GT
  • Adizzle843
  • Feb 5, 2026
SN95 4.6L Mustang Tech Feb 17, 2026
Adizzle843
  • Gulftown980x
  • Jul 29, 2026
squeak93
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
F
Spark Plugs Caused Rough Idle & Driving
  • firevert
  • Sep 1, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 3, 2025
