oil pan gasket
pnyinprgrs
27
how hard is it to replace the oil pan gasket on an 89 . The shop I got it inspected at said around 30-60 for the gasket then 237 to install it. If it is eaasy I would rather do it myself and not pay the bloody labour.
seems a little high for labor. then again i havent been to the shop for repairs in a long while, so i wouldnt know. I fix my own crap lol.
Its a PITA but the procedure is simple.
buy a felpro 1 PIECE gasket, its blue in color. reusable, and requires no sealant. Much much easier to install. and only like 20$ at parts stores. just the ease of installing is worth buying it. wont have to jack with sealant.
and also it comes with 4 little pieces that thread into the 4 big oil pan bolts in the corner. Then there is a clip that allows the gasket over it and they will hold the gasket up. SO EASY.
unbolt motor mounts, jack the engine up as far as possible. unbolt the pan, get rid of old gasket and stick the 1 piece one in, you have to work it around the oil pump.
It wont be easy but will save you over 200 for the labor....
Been there, done that - You can do it in the car, but it is hard to do. The best way is to pull the engine.
Disconnect the battery at the battery ground terminal, remove the fan and fan shroud. Both motor mounts will need to have the large nuts that secure them to the frame removed. The trans mount will also have to be loosened, and it is a good idea to remove the drive shaft.
I also had to disconnect the cat pipes at the headers to get the engine high enough to remove the oil pan. Be prepared to have to drop the steering rack and disconnect the steering shaft. Jack up the engine with a wood block under the oil pan and watch for things that bind or hoses/electrical wiring that may need to be disconnected. I put a couple of wood blocks between the headers and the frame to support the engine. You will likely need to jack up the rear of the transmission as well to get the required clearance.
Scrape the pan mating surfaces clean as possible - old gasket stuck to the surfaces are a source of leaks.
There is a one piece oil pan gasket which will help re-assembly if you can find it. If you can't get this gasket, use weather strip adhesive to secure the cork gasket to the pan rails and the rubber strips to the bearing caps. Read the instructions on the adhesive carefully to make sure the gaskets are permanently stuck in place and won't move when you slide the pan in place. Use lots of blue silicone sealer on top of the front and rear rubber seals where they mate with the pan.
Fill with oil, replace the filter. Reconnect the battery, switch the ignition on to enable the gages, but DON'T crank the car. Remove the distributor and use a 1/4" hex socket to turn the pump counter clock wise (same direction as distributor rotation) until you see oil pressure (an external gage is a great help long about now). And keep turning for about 30 sec after you see the pressure come up. A reversible drill is the best tool to use to turn the 1/4" socket. The pressure should come up to about 50-80psi with cold oil. Once you see good pressure, check for obvious leaks, and then and only then, lower everything back into place and bolt down the mounts and anything else you had to take loose.
Re-install the distributor and set the timing with the engine running using timing light (don't forget to disconnect the SPOUT plug and reconnect it when finished) 12-14 degrees BDC is good. Start up and check for leaks, let it warm up and look again for leaks. It took me 2 days plus, but I am old and slow, maybe your granny is faster.
