Oil Pickup Clearance
  • Thread starter Thread starter RangerJoe
  • Start date Start date Feb 13, 2011
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Feb 13, 2011
  • Feb 13, 2011
Hey guys, I'm currently rebuilding my motor and have gone with a 331 kit. I ordered ARP studs for the mains and a Melling HV oil pump and I am reusing the stock pickup and oil pan (all from a 1988 motor).
I clayed the pickup and only found .205" of clearance, which is below what is recommended. Then I realized that the pan was not seating all the way. Finally figured out that the pan was making contact with the pickup tube around the number 2 main.
After an hour of head scratching I figured out what it is. If you look at the stock number 3 bolt with the stud for the pickup, the head of the bolt is very short, maybe less than a 1/4" tall. The ARP stud uses a washer, which is almost as tall as the head on the stock bolt, followed by a large nut, which is double the size in heigth of the stock bolt. This pushes my pickup assembly down towards the oil pan probably close to a 1/2". Thus creating the interference.
I am waiting for Monday so I can call ARP and ask them about it. I replaced the one stud with the stock bolt and verified that it did work with the stocker, but I don't want to run it like that if I can use the ARP stud. Has anyone else had this problem? If so, how did you correct it?
Thanks!
J
jerryD
1,061
Gladstone, MO
Feb 14, 2011
  • Feb 14, 2011
i forget what bolt setup i used on mine, but i heated up my pick up tube which a torch so that i could bend it to the proper clearance. still working so far with maybe 10k on motor.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
D
Resolved Oil pan welds cracking
  • D & D Racing
  • May 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 16, 2025
revhead347
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
