oil press.gage? help!!!!
FEESER 94 COBRA
142
oil press.gage? some one please help !!!!!
Were does the oil press. gage get hooked to in our cars?I know where they get hooked to on the fox bodys but there doesnt seem to be any thing that even looks simeler on my 94 cobra ????
You have to remove the sending unit, its in front of the oil filter, screwed into the block....feed your line from there to your gage..
No, the upper doesn't have to be removed....the regulator sits on top of the fuel rail right behind the intake on the passenger side...remove the 2 allens, and replace it ....
Here's a pic with a Tee i put in so as to have the stock gage work also...you can see the factory sending unit in there...yours will be screwed into the block..the kit has the correct nipple...unscrew the stocker and feed yours in...Its tit... :D
