Oil Presssure Jumping Around
johnsonsinutah
20
I own a new to me 1997 Cobra, when I start it up the oil pressure reads just to the high side of the gauge mid-point, when I drive moderatly no change, when I start to rev up past 3500RPMs or so, the needle starts to jump around then move towards the low side of the gauge until I shift, then it goes back to normal and as I start to rev it goes through the cycle again. When I stop, the gauge sits right back at just to the high side of the mid-point...any idea what may cause this? Bad gauge? bad sending unit?
Thanks
It's probably a sign that your sending unit it about to fail. Might also be a bad ground somewhere, but it's more than likely the sending unit.
The factory oil pressure gauges in these cars are nothing more than idiot lights and read about "halfway" as long as there is +/- 6 psi of oil pressure. They shouldn't bounce around or move.
I've had the factory oil pressure sender die and had to replace it as well - pretty easy task, maybe less than $12 for the part IIRC.
