Oil Pressure Gauge Install
acutron42
Hello all,
I just finished a gauge pod install & used a Prosport sandwich adapter for the oil pressure sending unit. The stock oil filter would not clear the sway bar so I used a Moroso 22463. I am seeing 75 psi @ start up, 40 psi @ idle warm & 50-60 cruising. Has anyone used this filter before? The bypass valve is rated about 3 psi below stock & am wondering if this set up is ok. I have no other mods except for a Cervinis ram air set up. Any feedback would be greatly appreciated!
Tom
