Oil Pressure Sending Unit?
  • Thread starter Thread starter jrcg92
  • Start date Start date Jan 14, 2014
1 of 2 Next Last
J
jrcg92
38
  • Jan 14, 2014
Hey everyone. I've realized that my oil pressure gauge isn't really a pressure gauge. It tells you if it's in normal range. I bought a mechanical oil pressure gauge but now I can't find the sending unit so I can install the new one. If someone has pics of theirs that would be awesome.
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Jan 14, 2014
  • Jan 14, 2014
it should connect near the oil filter on that looks like a small pipe.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Jan 14, 2014
  • Jan 14, 2014
Exactly as above. Directly above the oil filter on the drivers side is the sending unit. Should only have one wire going to it. Its a large round sensor.
J
jrcg92
38
  • Jan 14, 2014
Is my car going to freak out if I don't reconnect the sensor? Or is there a way to ground it
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Jan 14, 2014
  • Jan 14, 2014
would will need to remove the round sending unit to attach the hose for the mech gauge.
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Jan 14, 2014
  • Jan 14, 2014
You can T it off so your stock gauge isn't dead. It always bothered me so when i swapped engines i hooked up both.
Do it help anything? No, but only cost like another $5 in fittings.
J
jrcg92
38
  • Jan 14, 2014
Ok. Cause I don't really care if it's dead. Might as well be cause only tells you when it's dumb, hungry or fat.
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Jan 14, 2014
  • Jan 14, 2014
Agreed I hate dead gauges. I spent tones of time getting my gauges to work with the BS3
Grabbin' Asphalt
2,029
310
124
Atlanta, Ga
Jan 14, 2014
  • Jan 14, 2014
Hate a dead gauge too, just gotta read something!!!
madspeed
Colonel Mustard
1,332
204
a van down by the river
Jan 14, 2014
#10
  • Jan 14, 2014
  • #10
agree also, dead gauges are horible, you will still look at it and be like oh chit
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Jan 14, 2014
#11
  • Jan 14, 2014
  • #11
Do I sense paranoia in this thread?
Reactions: 88LX5.Oh
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Jan 14, 2014
#12
  • Jan 14, 2014
  • #12
dont tell me you have dead gauges in your car!
unacceptable to me in my street car.
J
jrcg92
38
#13
  • Jan 14, 2014
  • #13
I use mine for SCCA events. So I need an accurate reading on my oil pressure.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Jan 14, 2014
#14
  • Jan 14, 2014
  • #14
I have the fast dash in mine so no dead gauges here
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Jan 14, 2014
#15
  • Jan 14, 2014
  • #15
I knew I liked you for some reason!
Reactions: 84Ttop
toyman
1,944
54
79
Vernon BC
Jan 14, 2014
#16
  • Jan 14, 2014
  • #16
So exactly what does an accurate reading do for you and what reading "freaks" you out?
J
jrcg92
38
#17
  • Jan 14, 2014
  • #17
Well on the stock gauge, normal is a pretty wide margin. Honestly, how did this conversation turn into how it freaks me out? Just don't like it. Precision is what I need. Not oh hey it's normal even at 75 psi or 20 psi.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 15, 2014
#18
  • Jan 15, 2014
  • #18
Don't skip installing the flow restrictor described in the bottom of this tech note. It's a guaranteed engine saver if the hose springs a leak!
Mechanical oil pressure gauge installation..
1.) Remove old pressure sender. It is located down by the oil filter and has 1 wire on a push on screw connector.
2.) Install ¼” pipe tee fitting with a short ¼” nipple on the place where you removed the oil pressure sender.
3.) Install the original oil pressure sender back in one of the tee ports.
4.) Install the gauge line restrictor in the remaining port of the tee.
5.) Connect the flex tubing or hydraulic hose to the gauge restrictor. Be sure to route the tubing or hose away from the exhaust manifolds. Be sure to either use hydraulic hose or oil and heat resistant flex tubing for the pressure line. Do not use copper tubing for the connection to the gauge restrictor or engine. Over a period of time, the vibration will work harden the tubing and cause it to crack and fail.
6.) If the gauge is going to mount under the hood, connect it to the end of the hose or flex tubing. Use some Tie-wraps to secure the gauge and its plumbing to the wiring harness on the driver’s side inner fender.
7.) If the gauge is going to mount in the passenger compartment you get to find a place to run the tubing through the firewall. I suggest that you pick your spot from the inside since that is the area with the most difficult access. Do not run the tubing through the exact same hole as the steering shaft. It will tangle up with the steering shaft and cause major problems.
8.) Install the gauge inside the car in the location of your choosing. Connect the pressure line to the gauge and secure it out of the way of moving parts with Tie-wraps.
9.) Be sure to ground the gauge lighting wire to clean, shiny bare metal. Connect the other wire from the gauge lighting to a light blue/red wire on the radio wiring harness. There are 2 connectors in the radio wiring harness, but only one of them has the light blue/red wire you need for gauge illumination. Solder the gauge lighting wire to the light blue/red wire on the radio harness and cover the soldered joint with heat shrink.
How to solder like a pro - Ford Fuel Injection » How To Solder Like a Pro a must read for any automotive wiring job.
Be sure to use a gauge restrictor fitting in the pressure line going to the gauge. The restrictor will prevent all of the engine's oil supply from ending up on the pavement before you can stop it if the gauge line fails. I had a gauge line rupture, and the restrictor fitting saved my engine from serious damage.
J
jrcg92
38
#19
  • Jan 15, 2014
  • #19
Do you have a pic of this thing installed? And this is a great write up.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 15, 2014
#20
  • Jan 15, 2014
  • #20
You'll get a better ide of what it looks like by using the drawings. Photographs of these small parts tend to blur the details in with the background stuff.
1 of 2 Next Last
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
G
oil pressure
  • Gandalf79
  • Feb 5, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 12, 2024
Gandalf79
G
