DemonGT Founding Member May 24, 2002 871 51 49 Sparta,WI May 24, 2023 #1 May 24, 2023 #1 Im not using my egr. Can i wire in a sensor for oil pressure to the egr?
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,356 21,558 234 Box behind Walmart May 28, 2023 #2 May 28, 2023 #2 You have a PimpXS. I don't see why not. You just have to tell the EEC what to do with that 5V signal.
8 86HO5.0 Active Member Apr 18, 2023 262 173 53 Raleigh, NC Sep 18, 2023 #3 Sep 18, 2023 #3 Demon-- Have you completed this? What sensor did you use? This is going to be one of my winter projects.
DemonGT Founding Member May 24, 2002 871 51 49 Sparta,WI Sep 18, 2023 #4 Sep 18, 2023 #4 No actually. I plan on installing a dd efi dash at some point and that will have oil psi. I was going to use a sensor from www.lowdoller-motorsports.com
8 86HO5.0 Active Member Apr 18, 2023 262 173 53 Raleigh, NC Oct 1, 2023 #5 Oct 1, 2023 #5 Finished this today, reassigned map pin 45 to pin 43 and setup the sensor in TunerStudio. Bought a GM 12677839, fit great! Now I can view actual oil pressure through Shadow dash rather than the OE dummy gauge. Reactions: DemonGT
