oil pump installation?
  • Thread starter Thread starter Beef97
  • Start date Start date Oct 12, 2005
Beef97
46
Corpus Christi, Texas
Oct 12, 2005
  • Oct 12, 2005
Hey guys, how hard is it to install a new oil pump and pan while the engine is still in the car? Is it important to change them? How bad (or good) was the original? What is the deal with all these high volume oil pumps? If you could recommend any brands that you've had success with that would be huge as well! Thanks again for all of your info!
iskwezm
4,159
20
79
Rowland Heights,California
Oct 12, 2005
  • Oct 12, 2005
changing the pump isnt much harder then dropping the pan and a few bolts holding the pump to the block.
Melling is one of the more widely used pumps.
cardude
221
Portland, OR
Oct 12, 2005
  • Oct 12, 2005
at least on a 66 you just remove the cross support (two bolts) and you are pretty much open to drop the pan. give yourself some room though it gets really tight under there!
69 Rustang
307
Orange County California
Oct 12, 2005
  • Oct 12, 2005
It depends what year car you have. 71-73's have a fixed crossmember so the engine must be jacked or lifted to allow pulling the pan. This can be done in the car though. On earlier cars, piece of cake--remove the crossmember and unbolt the idler arm, you should be able to drop the pan.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Oct 13, 2005
  • Oct 13, 2005
The others covered the simplicity of changing a pump(my '65 notch needed it three times). Its not important to change them unless you're rebuilding the engine. Dont bother with a high volume unless you have a race engine with loose tolerances. I also recommend getting a hardened oil pump shaft. I only have experience with Melling pumps which are really the standard that nearly everyone uses.
1966conv
220
  • Oct 13, 2005
One thing that should be mentioned about the crossmember----be careful and don't snap the bolts off.
If everything is original and thoses bolts have never been removed, there is a good chance they're rusted tight. If you break them off you got yourself a real buttache drilling and retapping. Give them a shot or two of pb blaster each day for several days before attempting.
65ShelbyClone
4,675
38
119
Oct 13, 2005
  • Oct 13, 2005
Yeah, even the crossmember bolts on my California desert car were tough to remove.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
