oil pump or guage problem?
  • Thread starter Thread starter lang williams
  • Start date Start date Sep 20, 2005
L
lang williams
567
cleveland, oh
Sep 20, 2005
  • Sep 20, 2005
HI....i stopped at a stop light driving home tonight an looked down an saw near zero oil pressure! I pulled off the road, an noticed that when i gave the engine gas the preasure went back up. I added a quart (it was a little low) an drove on home...the guage would read zero or near zero when idling or under braking..an norm when cruising....is something wrong witht he guage/sensor or should i park it an put a oil pump in? its the stock pump on a 87 5.0 with 58K on it..thanks for advise.
Modular2v
3,222
23
99
oklahoma
Sep 20, 2005
  • Sep 20, 2005
i would do a new guage 1st....if that doesnt work pull the pan and put a new pump in....good luck
sgarlic
3,085
Sep 20, 2005
  • Sep 20, 2005
I'd replace the sending unit before I bothered trying the oil pump. I also would try an aftermarket gauge.. even if it's only temporarily, since the stock gauge can be way off.
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
Sep 20, 2005
  • Sep 20, 2005
Definetly most likely the oil pressure sending unit... they do go every so often. Try replacing that first as it's fairly cheap. It's located on the left side near the oil filter just incase you didn't know.
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
  • dan50
  • Jul 18, 2026
dan50
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
